How much torque can the th400 take??
Old Jul 15, 2005 | 11:09 AM
pauvil's Avatar
pauvil
Default How much torque can the th400 take??
I have a 75 L-48 with the th400 trans (stock). How much power can I put to this trans???
Old Jul 15, 2005 | 11:30 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't think you can make enough power to hurt it. I had a nitrous bigblock with slicks that couldn't do it harm.
Old Jul 15, 2005 | 11:50 AM
pauvil's Avatar
pauvil
I want to dump a 454 in this, about 500lb. ft. of torque, do you think it will hold?? it's the original trans with 38,000 original miles.
Old Jul 15, 2005 | 12:57 PM
norvalwilhelm
If you want a little firmer shift install a shift kit while the transmission is out. The kits are easy to install if you just follow the instructions.
I feel the 400 is plenty strong.
Old Jul 15, 2005 | 01:39 PM
Razorhorn's Avatar
Razorhorn
I'm also putting in a big block mated to a TH400. I hope it breaks because it's the only way "the boss" is going to allow me to spend any more money.
Old Jul 15, 2005 | 02:35 PM
gerry72's Avatar
gerry72
Originally Posted by Razorhorn
...I hope it breaks because it's the only way "the boss" is going to allow me to spend any more money.
Find a rough concrete street and do about 30 or so neutral drops with the throttle on the floor. You'll have a new trans on order as soon as the tow truck drags your butt home.
Old Jul 15, 2005 | 04:05 PM
MassVette's Avatar
MassVette
Chevrolet sold L-88 Corvettes with TH400's. They're tough.
Old Jul 15, 2005 | 04:08 PM
Empatho's Avatar
Empatho
Old Jul 15, 2005 | 04:16 PM
mongo6901's Avatar
mongo6901
O.K., through carelessness and ignorance you can break anything. Actually, in the above example, I'd bet your u-joints or driveshaft goes first.
But a TH400 is as bulletproof as you can get.
GM routinely shipped (with a warranty) TH400s in LS6 Chevelles (and Corvettes) and Buick Stage I GSs and they both had over 500 lb ft of torque.
Old Jul 15, 2005 | 04:40 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
I know of a few 1000+ hp heavy street cars with stock 400's. They are pretty tough. Even if you do break it the parts to make it even more bullet proof are pretty cheap
Old Jul 15, 2005 | 04:59 PM
GTR1999's Avatar
GTR1999
Change the 2nd gear drum and roller to an earlier drum and 32 element sprag this was one of the weak areas. There are a lot of mods to do to them. I have one ready to bolt up to the engine I'm building now. The 400 will be overkill for this engine but it's all numbers matching.
Iused the B&M trans Kit which has most of the parts to overhaul one, but not all. It does have good instructions for rebuilding and mod'ing it too. Make up an stand to use on an engine stand and get a book and video and go to it!
Good luck,
Gary
To How much torque can the th400 take??
