Rims for a '78
Old Jul 15, 2005 | 01:57 PM
ChevyTuner1122's Avatar
ChevyTuner1122
6th Gear
Default Rims for a '78
I am in the process of modifying my '78 and have checked into many different styles of rims. I have recently installed a Richmond Gear 6-Speed with a stage 1 Kevlar clutch. Will 8' tires be enough to grab traction or should I go wider. Also, if I go wider on the rear, should I do the same on the front (how wide can I go on the front?)
Old Jul 15, 2005 | 02:02 PM
Empatho's Avatar
Empatho
Old Jul 15, 2005 | 02:16 PM
The Money Pit's Avatar
The Money Pit
I have 10" wide P295 50-s and a 700r4 with 3.70 gears. I intentionally went with only 2200 stall and still there's no chance of any traction if I nail it.On wet roads I've accidentally gone sideways just catching second.
I did not have this "problem" with the 350 engine though.Not sure why........
Old Jul 15, 2005 | 03:35 PM
ChevyTuner1122
6th Gear
Are those 10" on the front also? I'd like to be able to rotate them if needed.
To Rims for a '78
