window adjustment
Old Jul 15, 2005 | 08:10 PM
strack350's Avatar
strack350
Default window adjustment
the title says it all, after i replaced my door panels in my 76 with new ones, my drivers side window motor quit working , so i took it all apart and installed a new motor. After i put it all back together the window goes up fine with the door open, but when its closed, the top goes in too far and ends up inside the weatherstripping instead of outside like it is supposed to be. It also goes up harder than it should like its in a bind when the door is closed. After looking around on the inner door, i found that i can adjust it at the top of the door for in/out movement, but this is not working. is there any other adjustments to make? any help is appriciated.
Old Jul 15, 2005 | 10:26 PM
Bennie's Avatar
Bennie
1st Gear
check past threads. A very good explanation & diaghrams is avaliable
