Offset Trailing Arm Comparison
Old Jul 16, 2005 | 01:30 PM
MIKE80's Avatar
MIKE80
Default Offset Trailing Arm Comparison
I bought VBP offset trailing arms and was going to rebuild the trailing arm assembly myself, but decided instead to sent them to Van Steel for rebuilding. My question is, how does Van Steel offset trailing arms compare to VBP. VBP say that their trailing arms are the only one with a full size bushing on their website and are also made of box steel, compared to Van Steels plate steel. I ask this because when I got them back I had new Van Steel offset trailing arms, not the new VBP offset trailing arms that I sent. Is it worth correcting?
Old Jul 16, 2005 | 02:16 PM
MikeC's Avatar
MikeC
Take pictures of the VBP offsets and I'll compare with my Van Steel's.
My Van Steels look way over built, to me the benefit of "box" steel would be nil. I am assuming by box steel the mean Rectangular tubing
Old Jul 16, 2005 | 02:45 PM
MIKE80's Avatar
MIKE80
MikeC
I originally bought VBP offset arms, but got the assembly back with Van Steel arms. There is a picture of VBP offset arms on their website.
Old Jul 16, 2005 | 03:09 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
VanSteel builds the Off Set Trailing Arms for VBP and most other people selling them.
Old Jul 16, 2005 | 03:26 PM
bahamasair's Avatar
bahamasair
So does that mean Van Steels arms also use a full sized bushing? Looking at the pics of the 2 arms they do look slightly different are you sure they are the same?
Old Jul 16, 2005 | 05:20 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I thought the plate ones were the extra cost heavy duty ones?
Old Jul 16, 2005 | 11:28 PM
68/70Vette's Avatar
68/70Vette
If you look at the catalogs you'd think that some of the the Van Steel and VBP parts are the same. The suspension "packages" look the same and other parts seem visually similar. I ordered a suspension backage from Van Steel and the composite spring had a VBP logo on it.
Old Jul 16, 2005 | 11:45 PM
LiveandLetDrive
Many of them are, some VBP makes for VS, some VS for VBP. I've dealt with both and done well.
-Chris
Old Jul 17, 2005 | 08:21 AM
MIKE80's Avatar
MIKE80
The offset trailing arms that I received from VBP before I sent them out to Van Steel are definitely different than what I got back. Box steel vs. plate steel. Look at the two websites. They are not the same.
http://www.vbandp.com/detail.aspx?ID=596
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1837
Old Jul 17, 2005 | 08:49 AM
Vette_Tech's Avatar
Vette_Tech
Wrong, VBP's are plate steel and can use (stock rubber or poly bushings), The offset upper A arms are tubluar steel
Old Jul 17, 2005 | 11:31 AM
MikeC's Avatar
MikeC
I looked at both and both are made out of plate steel. Maybe VBP's has a different bushing in it, I'm not sure.
Like I said I have Van Steel's Offset's and have no problems with running them.
I think you are worrying too much about a non existent problem. If you want your VBP offsets back give Van Steel a call they are great to deal with maybe they'll work a deal so you can get the VBP offsets back
Old Jul 17, 2005 | 01:58 PM
MIKE80's Avatar
MIKE80
I just thought one might be better than the other. Maybe I was wrong about the box steel. Anyway, the quality looks well built and you guys say there's no difference, so I guess I'm not going to worry about it. Thanks for the input.
Old Jul 17, 2005 | 02:54 PM
bowtie racing's Avatar
bowtie racing
Look again .. they are 100% same ! Just photographed different side. I have personally had one set bought from vb. And they were exactly same.
Old Jul 17, 2005 | 11:22 PM
68/70Vette's Avatar
68/70Vette
There are other manufacturers of offset trailing arms. Tom's Differentials have their own offset trailing arms that they sell. Also Guldstrand sells their own offset trailing arms. Tom's offset trailing arms are manufactured with plate steel and do not have provisions for an anti roll bar. If you want to run max horsepower with a Corvette IRS, I think you have to get Tom's stuff. Guildstrand modifies a stock box steel offset trailing arm. Guldstrand charges about $900 for their offset trailing arms and Tom's charges about ther same price as VBP.
Old Jul 18, 2005 | 01:14 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Our arms are not the exact same. We so use a different style bushing and our offsets do not have large oval holes. The pic of VBP's offsets must be an old picture.
If you buy their offsets we will install them and give you their arms. We wouldn't have switched them out. I don't have any of their offsets in my building. Does the bushing look like a stock bushing or is it smaller. If it's stock, than they the VBP offsets. They will also have the 2 large oval shaped holes in their arms. Mine are just like the pic provided in the link above.
Here is another pic of my units
Old Jul 20, 2005 | 06:49 PM
MIKE80's Avatar
MIKE80
The arms I have, do have the oval cut-outs and I don't think that the bushing is smaller than stock. Sorry, I'm not trying to accuse you guys of switching arms, just thought I got different ones by mistake, guess not. The picture on VBP's website must be an old one, and didn't help.
Definately a NICE job on rebuilding the trailing arms. Highly Recommend. Thanks.
Old Jul 20, 2005 | 10:48 PM
White 68's Avatar
White 68
Van Steel how about running a special on those offset arms ...I,m in the market ...How big of a tire and wide of rim can I fit under my 68 on the rear with 17 inch rims ..Thanks
I,ve heard 295x50 on a 17x8 icnh rim 4' back space
To Offset Trailing Arm Comparison
Old Jul 21, 2005 | 12:39 AM
Stumpdeisel's Avatar
Stumpdeisel
Was wondering the same thing, can't seem to find it in the catelog...
Old Jul 21, 2005 | 10:32 AM
Van Steel's Avatar
Van Steel
I only have 6 sets of arms left. I'm waiting for 100 more set to be made. Shouldn't be any more than a couple weeks out. I'd be willing to do something.
17 x 9 285/40 or 295/40 5" backspace. 18 x 10's will work w/305's in the rear.
Old Jul 21, 2005 | 10:33 AM
Van Steel's Avatar
Van Steel
Catalog #22 & 23
On page 2
