Oilpreassure jumping + datacheck
I have a 1982 CE with crossfire injection fuelsystem.
Is it so that if I connect the datacheck to ground on the socket under the ashtray the "check-engine" - lamp will give me the codes by blinking as discribed in Heynes ? Or how does it work. I can´t understand Heynes in this detail and daren´t try before I have knowledge.
Can anyone tell me reasons to why the oil-preassure-gauge jumps heavilly in certain rpm`s ? Most of the time its steady as a rock at 40.
I have problems with stalling engine at low rpm´s and idle. Also bad performance in low rpm´s after an idiot filling the tank with water and coolercement but I figure the oilpreassure shouldn´t jump hysterically when the engine runs and only at some rpm´s.
I´ve tested by slowly increase and decrease rpm´s and the gauge starts jumping at different rpm´s.
Thanks a million for any answer
Hebbe
It seams as this was the fault that have troubbled me sleepless for a long time. I have driven the car for one day in different situations with a lot of idling and stopping the motor. And it seems allright. I´m so happy I cant say ..........!!!!!!!!!!!!!!!!!!!!!
But I still have a jumpy oilpreassure-gauge a some rpm`s. Is the sensor in the engine known to create such signals ? Can it be a simple electric problem with bad connection or should I even worry about the oilpump ?
Thanks for any answer !
