Lowering my 73
Old Jul 17, 2005 | 06:08 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Lowering my 73
Will new shorter coil springs (F-41?) lower my BB 73? I just installed 17" TT II's with 245 45's and would like to eliminate the space between wheel well and tire. If so, how big of a job is this? Type of springs? Tricks?
Old Jul 17, 2005 | 06:19 PM
70 LS1's Avatar
70 LS1
The 550lb springs will lower the front about 1". You can also cut the stock springs removing 1 coil will drop it about 1-1.5".
It is pretty easy to change the springs. There have been a few different methods discussed on the forum before. Do a search and see what you can come up with.
Old Jul 17, 2005 | 06:42 PM
Techno's Avatar
Techno
If your buying new springs why not get the front glass spring. I understand it not only gives a better ride/handling but is height adjustable.
Plus your cake is lighter!
Old Jul 17, 2005 | 06:44 PM
Red73's Avatar
Red73
I would start with the 550lb springs first. If you need to cut your springs I would only cut a quarter of a coil at a time. You don't want to cut to much and be too low unless you want to buy another set of springs.
Old Jul 17, 2005 | 08:34 PM
73jst4fun's Avatar
73jst4fun
I just recently changed the springs, having a small block/AC I went with the 460's. With 245R60/15 tires I ended up cutting 13" off total, but in two sessions. The 550's will be the choice for you, installed they should bring your front down 1", as Red73 stated you dont want to cut too much off, also depending what mods you have made and options (aluminum heads, A/C, lighter components) cutting the springs should be done sparingly. BTW the outside spring measures 16 1/4" with a cloth tape......good luck, it's a fairly easy job, just installing, removing, cutting and re installing is time consuming....
Old Jul 17, 2005 | 10:05 PM
Glassbowtie77's Avatar
Glassbowtie77
I just bought VBP 550 lb. springs for mine, 1"-1-1/2" drop.
To Lowering my 73
