Well, if it helps, HEI distributors are the same....
They might have used some different weights on mechanical advances or settings on non-adjustable type vacuum advances, but in general big block and small block distributors are the same. I don't know what differences they may have chosen to make on mechanical distributors, but the essential mechanisms and gears are the same.
Raised deck versions of both small and big blocks can also use the same distributors, generally providing there is an adjustable slip collar to change the depth. The "super depth" blocks (my holy grail) are supposedly so different an elongated shaft and housing/tailstock thing are required.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Well it's about time, another big block/small block shootout well let me start by saying you can't go wrong with a big inch small.... oh distributors,
never mind
never mind
never mind
never mind
During the 1968 season, "THE OLD RELIABLE" Z/28 ran elapsed times of 11.70's at 116 mph keeping up with many Super Stock 396 Camaros! This was a stock Z/28 intake manifold and carburetor, stock hood, Stahl Headers, 5.38 gears, and nine-inch slicks.
Strickler's Camaro is still equipped with an original balanced and blue printed 302 engine. In 1998, "OLD RELIABLE" ran consistent elapsed times in the 11.20's at over 119.00 mph, (and that's without a crossram!). Not too bad for a stock 302 engine. In 1994, the "OLD RELIABLE" Z/28 Camaro won the prestigious "Best of Show Award" at the US Camaro Nationals held in Dearborne, Michigan. In 1995, MacNeish finished the racing season placing 11th in Division One out of 185 drivers in NHRA's Stock Eliminator Class.
