Timing technique-which do you do?
Old Jul 19, 2005 | 10:41 PM
Techno's Avatar
Techno
Default Timing technique-which do you do?
I see a lot of degrees advice for timing. Do you set your timing to a value of degrees?
Or road test the car and set the timing that way.
Old Jul 20, 2005 | 12:18 AM
StickShiftCorvette's Avatar
StickShiftCorvette
I start by setting to a high performance specification 12 degrees BTDC. If it knocks under load with the gas I normally run I back off 2 degrees at a time until it is OK. Once I know the sweet spot, I reset to that value when changing points, rotor, or cap.
Old Jul 20, 2005 | 12:31 AM
WhichVette?'s Avatar
WhichVette?
I set to 36 degrees under full mechanical advance with the vacuum advance plugged, then adjust with road testing.
Old Jul 20, 2005 | 12:37 AM
rcread's Avatar
rcread
I do that too. Piece of cake with the right timing light.
Old Jul 20, 2005 | 01:00 AM
comp's Avatar
comp
find out what octane fuel it going to be put in it most of the of the time first
Old Jul 20, 2005 | 08:15 AM
djgrelli's Avatar
djgrelli
I found from experience over the years to just set it to factory specs if you're running a stock engine. When you start to modify by changing cam's, valve trains, carbs, etc, etc you should then go with the total degree way which is usually 36 degree's on a SBC. Just went thru this with my son's 327 on his t-bucket. Seem's 34-36 total is fine. We're not running any vacuum advance so this is total in around 2800 RPM's.
Old Jul 20, 2005 | 08:29 AM
Gordonm's Avatar
Gordonm
If your dist. has over 30K miles on it just setting it to factory idle specs is not going to cut it. They wear out and the advance will be more than what is needed. Mine was supposed to give a total of 36 and it had over 50. The plate was worn after only 45K very badly. I took it to a guy with a dist machine to have it set up. I had 14 to 16 initial and 36 total. I am now working with vacuum cans to get the idle even better. I only pull about 10 inches at idle so a VC1810 can is going in. I am shooting for around 26 degrees at idle with the vacuum can running manifold vacuum. It idles very nicely at this timing. I have it set at 36 total and this seems to provide the best times at the strip and the best driving. I have never been able to get this motor to detonate. It has a lot of duration and only around 10 to 1 compression with aluminum heads. Every combo is going to be different and needs to be optimized. This is why Lars is so popular. He knows what he is doing when it comes to timing.
Old Jul 20, 2005 | 08:49 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Originally Posted by Gordonm
I had 14 to 16 initial and 36 total....... I have it set at 36 total and this seems to provide the best times at the strip and the best driving.
I set mine with a advance re-curving kit to 36* at 3000 rpms and 16* at idle. Used a adjustable timing light to do it. Off on a road trip and afterwards. Of course I also freed up the stuck mech advance while I was at it so it was night and day.
Old Jul 20, 2005 | 08:55 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
OK....Here's a curve ball for you. If I have a Pertronix Ignitor II installed ... Does the Pertronix module take care of the ADVANCE or do the springs still control the advance rate. My 72 calls for 8 degrees - I have it set at 10 degrees at idle with the vacuum capped during adjustment. Runs good - but I always look for ways to improve.
Thanks for any feedback.............
Old Jul 20, 2005 | 09:44 AM
Gordonm's Avatar
Gordonm
The Pertronix has nothing to do with the advance of the timing. It is controlled by the springs and weights and the vacuum advance. The Pertronix just sends the "fire" down the line to the plugs.
Old Jul 20, 2005 | 12:17 PM
Hef's Avatar
Hef
Default 79 vette timing
I would like to check the timing on my 79 vette.(42k miles) Its running ok, it just hasnt been done since???? (probably 15 years) I would like to set the timing for best performance with the fuel I use which is 91 -93 octane.
Should I just check it at idle per factory specs? is this good enough? From what I have read, you need to also check it at full advance, to see what the timing is at that point - is this correct? I read Lars paper, and it indicates that for a HEI ignition (which I think I have) you need to install a soft set of springs if you want to check timing at full advance. Where would I get softer springs? How are they identified? Thanks,
Hef
Old Jul 20, 2005 | 01:22 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Any vette engine will run better with the total timing set at ~36. But you may need to modify the mechanical advance...
spring can be had at NAPA, autozone etc. just ask for a distributor recurve kit.
Old Jul 20, 2005 | 06:16 PM
fotyfobravo
Thanks...that makes sense....What threw me off was the Pertronix statement .... that the module....."monitors the dwell and constantly makes adjustments"
Old Jul 20, 2005 | 07:36 PM
Star79's Avatar
Star79
Hef
Here is what you get with the recurve-kit, which is under 10 bucks. New weights and bushings (Lars says use the old ones if you want) and three sets of springs, color coded. Black is softest. You don't have match them (ie two black or two silver) you can mix to get the advance you want (36* mechanical all in at 2800)
Old Jul 20, 2005 | 08:03 PM
Empatho's Avatar
Empatho
I used the Crane adjustable vacum advance kit
Old Jul 21, 2005 | 09:59 AM
Hef's Avatar
Hef
Default mechanical advance / vacuum advance
Ok there is mechanical advance and vacuum advance. If you have a manually adjustable vacuum advance kit like the one shown above, how does that help you adjust for the mechanical advance?
Old Jul 21, 2005 | 11:12 AM
Empatho's Avatar
Empatho
all it does is help you adjust centrifugal, and vacum advance
Old Jul 21, 2005 | 11:34 AM
WhichVette?
It adjusts vacuum advance with the can and mechanical advance with the springs.
Old Jul 22, 2005 | 10:03 AM
ruby76's Avatar
ruby76
adjustable vacuum advance helps you avoid the following:
lets say you set your intial timing to 16*, centrifugal is at 36* at 3000rpm so that is 16* plus 20* mech. Now if your crusing on interstate at 3000 rpms, you vacuum advance ALSO comes into play, if your vacuum advance pulls MORE than another 16*, you'll get MORE than 52* timing advance, any more than 52 and your in trouble with possibility of pinging etc, burnt pistons.
So if your vac advance would normally add 20*, you can adjust it to be a lower value of vac advance.
A "stock" smog 350 would be something like:
8* initial, 10* mech, + 20 vacuum for a total of 38* cruising
Make sense?
To Timing technique-which do you do?
