problems with rebuilt front end
Old Jul 20, 2005 | 08:50 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default problems with rebuilt front end
Hi, my dad and i put a new motor in his 1972 stingray and we also rebuilt the front end with all new rubber bushings. the problem is that the front end is sitting way to high and we cant figure out how to get it down. Any help or suggestions would be great thanks guys
Old Jul 20, 2005 | 09:03 PM
Retro78's Avatar
Retro78
Check that the springs are sitting properly in the spring pockets. The spring ends sit in a recessed area within the pocket against a stop. Actually they should not be right against the stop...perhaps 1/2" away. There are some small drain/alignment holes where the end of the spring should be located.
Old Jul 20, 2005 | 09:06 PM
Hitch's Avatar
Hitch
Did you tighten the "A" Arm bushings while it was still in the air? This seems to be the most common mistake that is made. Any rubber bushing shouldn't be tightened until the full weight of the car is on the suspension and been driven around the block. Then torque to spec... Dave..
Old Jul 20, 2005 | 09:10 PM
kona's Avatar
kona
Loosen the control arms to finger tight. Drive it around the block several times and then drive it up on ramps and tighten everything with the weight on the front end.
Kona
Corvette-Chris
St. Jude Donor '08
My dad is a professional mechanic and ownes a service station so we checked and double checked everything. The springs are in their correct pockets and we did tighten everything while the weight of the car was on it and then also drove it around the block. Still baffeled.....
Old Jul 20, 2005 | 09:16 PM
Hitch's Avatar
Hitch
Something ain't right... If you only replaced the bushings and not the springs... Than I don't care how good daddy is he's done one of the two things list above wrong... Dave..
Old Jul 20, 2005 | 09:18 PM
SkunkApe's Avatar
SkunkApe
Tell us about the springs. Was this a BB car that now carries a small block? Did you reduce weight significantly (e.g. aluminum heads, radiator, A/C removal)? Are the springs new? Are they the correct springs for the car?
P.S. - If your dad is a professional mechanic, why are you asking us?!? And, if you have an hour to spare, call me. I'll tell you the stories of how "professional/certified mechanics" have f'ed up my car, boat and work van...
Sign me,
Amateur mechanic & Gynecologist
Old Jul 21, 2005 | 05:03 PM
Hitch's Avatar
Hitch
Come on the suspense is killing me.... What does daddy have to say about all of this.......
Old Jul 21, 2005 | 06:48 PM
Techno's Avatar
Techno
You can measure the sitting height of the car to make sure it actually is sitting too high.
Old Jul 22, 2005 | 12:45 AM
SkunkApe's Avatar
SkunkApe
I think we (knuckle-dragging ruffians) scared him back to the safety & comfort of the C5 section:
http://forums.corvetteforum.com/sear...earchid=435407
Old Jul 22, 2005 | 08:34 AM
70vert's Avatar
70vert
Banned Scam/Spammer
We're not asking if "the springs are in there correct pocket" but "are the springs in the pocket correctly". BIG difference.
Old Jul 22, 2005 | 09:13 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Ruff crowd here. As mentioned above, it's one of the two things listed above.
Old Jul 22, 2005 | 02:27 PM
Jeff Garner's Avatar
Jeff Garner
Did you put the torch to those coils springs yet?
Old Jul 22, 2005 | 02:59 PM
NHvette's Avatar
NHvette
Be nice guys.
He is 19 and has a father that is still around. That is something - these days.
Remember back when you were 19 ... did you want anyone calling him your daddy ?
Qs: Did you put new shocks in - perhaps gas charged ?
Stock springs are tough to get back in the pocket correctly - double check this.
Last one: After replacing the bushings - and before installing
the control arms - could the shaft be rotated inside the inner sleeves ?
If not - perhaps the arms were slightly bent and binding up on the shafts.
We just did a members front end rebuild last weekend. In the
end, it looked to sit high. Unfortunately we did not measure
"before". After looking over old pictures, the owner stated that
it was sitting about the same as before.
I was worried, as we needed to torque one of the shaft bolts
BEFORE installing the arm (dang plastic radiator shrouds).
From now on, I am suggesting poly bushings to overcome this issue.
To problems with rebuilt front end
