Ignition box mount and floor boards
Old Jul 21, 2005 | 11:54 PM
ltlevil's Avatar
ltlevil
Default Ignition box mount and floor boards
I thought I would post this after I kept trying to figure out where to mount my Mallory Hy-Fire 6 (digital and fully adjustable with no "pills"). I debated on building a panel from the middle part of the roll bar, but that just didn't "feel" right. I needed it to be accesible so if I got ready to hit the juice I could set up the timing without having to move from the seat. Also if I needed to make any adjustments at the line I could do so from the driver seat. The other thing in the picture is I finished the drivers side floorboard fiberglass project and then sprayed it with under-coating the pass side will also be done this way. I also tried to show some "clips" that I made from metal tie down straps used when building a house (don't know the correct name for this stuff). I cut them off with two holes showing and rounded off the corners. You can then either fiberglass these in or use self tapping screws in one hole and run a tie wrap through the other to hold wires, looms or whatever. I am going to put down dynamat and carpet so I think it will turn out pretty good. Let me know what you think and any other ideas you might have.
