TH350 - What fluid?
Old Jul 22, 2005 | 09:13 AM
Chopper Larry's Avatar
Chopper Larry
Default TH350 - What fluid?
I'm gonna do my transmission service for my TH350; what brand and spc of fluid should I use? It has no leaks, and is not burnt, but is probably ready to change; also if I cannot do a complete flush, will it suffice to change the fluid again in say 2 or 3 days of driving, to get a better ratio of clean fluid?
Old Jul 22, 2005 | 09:36 AM
page62's Avatar
page62
Dexron III/Mercon. Doesn't need to be anything special, unless you like spending money for no good reason.
Old Jul 22, 2005 | 10:05 AM
markdtn's Avatar
markdtn
Yep, Dextron. You can change it again soon, but if it smells good now, 1 shot is probably enough.
Old Jul 22, 2005 | 11:37 AM
Pauld's Avatar
Pauld
Yep thats what I use
Old Jul 22, 2005 | 12:10 PM
Chopper Larry
That's what I went ahead and used...took a little over 3 1/2 quarts and the pan looked clean, and have no leaks so I'm good to go; next time in a few weeks I'm getting it flushed and an auxliary cooler (Heavy duty Ultra Cool) installed.
Old Jul 22, 2005 | 01:50 PM
gator79's Avatar
gator79
Default shift kit
a lot of shift kit manufactuers say to use type F because it has less friction modifiers and holds tighter. thats whats in mine and it works fine. mine has a shift kit in it. i think either fluid will work
Old Jul 22, 2005 | 08:31 PM
fl_rider's Avatar
fl_rider
Default An article I found..
Ready Reference for Lubricant and Fuel Performance
Driveline Lubricants — Automatic Transmission Fluids
Automatic transmission fluids (ATFs) are among the most complex multifunctional fluids available because they serve many purposes in the transmission, including:
* Heat dissipation
* Wear protection
* Lubrication
* Foam inhibition
* Shift quality
The full article is at this site:
http://www.lubrizol.com/ReadyReferen...tf/default.asp
To TH350 - What fluid?
