AMP Meter is not working, HELP
Old Jul 22, 2005 | 10:59 AM
Tombags's Avatar
Tombags
Default AMP Meter is not working, HELP
Hello,
My amp meter on my 1974 isn't working. I bought a new meter and replaced the one in my car and it still doesn't work. Does anyone have any suggestions or ideas how I can begin to troubleshoot this problem.
Thanks for your help
Tom
Old Jul 22, 2005 | 11:02 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Check the connections at the horn relay. Could be a bad connection here. Also while at the horn relay check to see if you have continuity across the fusible link. Both are easy to check.
Old Jul 22, 2005 | 11:07 AM
Tombags's Avatar
Tombags
Thanks for the advice. Where is the horn relay located???
Tom
Old Jul 22, 2005 | 12:26 PM
Eddie 70's Avatar
Eddie 70
It should be on the drivers side inner fender near the top, just under the fender lip. Anyone got a pic of the horn relay to show Tom the location?
Old Jul 22, 2005 | 12:35 PM
rcread's Avatar
rcread
http://www.madelectrical.com/electri...evymain1.shtml
There's a picture of a horn relay if you scroll down a bit, labeled "horn relay". It's not on a Corvette, but they pretty much look the same.
To AMP Meter is not working, HELP
