ventilation controls, part 2
Old Jul 22, 2005 | 11:21 AM
Shrike's Avatar
Shrike
Default ventilation controls, part 2
69 non A/C vert. Moving the drivers side wheel of the heater controls has no effect on where air comes out (just blows mostly out of the defroster vent, with a little coming out of the bottom of the system)
I think my previous thread was a little too confusing so I have an illustration of what I've done. This is just lifted from the AIM and I wiped out some of the non essential stuff:
basically, if I clamp the hose at the location with the red arrow, I have good vacuum in the whole system. I have felt around to the end of the hose and it seems to be attached to the actuator, but I can't see it without removing the drivers side dash panel (and I don't want to do that right now).
Does anyone know if it is normal for this line to be "open"?
Or am I on a wild goose chase?
Anyone know of a troubleshooting guide for the ventilation vacuum system?
Is there any way to tell if the actuator is bad?
How do I remove the actuator?
Thanks in advance,
Scott
Old Jul 23, 2005 | 12:27 AM
Shrike's Avatar
Shrike
I'm really hoping someone can help me with this, especially with the last two questions!
Scott
Old Jul 23, 2005 | 01:20 AM
griffths's Avatar
griffths
Shrike,
None of the connections under the dash should be open to the atmopshere. If the line to the actuator is not holding a vacuum then the actuator seal is ruptured and you will need to replace the actuator. A quick way to verify if the actuator is bad is to use a hand held vacuum pump and see if it will hold a vacuum. Haven't worked on a non-air car yet but it wasn't that hard to R&R the actuator on my car. Two speed nuts, two vacuum lines and a linkage were all that was connecting mine to the heater box.
Regards,
Jay
Old Jul 23, 2005 | 11:13 PM
Shrike's Avatar
Shrike
Great! Thanks for the info.
Scott
To ventilation controls, part 2
