Stumbles when hot
Old Jul 22, 2005 | 12:45 PM
MYBLU71's Avatar
MYBLU71
Default Stumbles when hot
I am having a problem with my '71. I had this problem before changing intake, carb and fuel lines. My old Qjet started leaking like a seive and needed replacement.
The issue is when it is cold, it runs great and has tons more response and power than with the old Qjet and stock manifold. But, once I reach operating temperature, it starts to stumble and hardly run when opening the throttle. I don't want to start another path of changing a ton of stuff, just finished that with the carb. Hopefully there are some ideas out there.
I have the stock fuel pump and a Mallory unilite distributor that has been converted from dual points to electronic pickup.
Old Jul 22, 2005 | 12:57 PM
pws69's Avatar
pws69
I would be VERY suspicious of the electronic pickup module (experience with Unilite talking here).... I have had similar behaviour with them in the past.
Old Jul 22, 2005 | 02:03 PM
DaveL82's Avatar
DaveL82
I can only speak from experience with GM HEI electronic ignitions. When the HEI module fails it usually runs fine when cold then does exactcly as you say when hot. Seems it can no longer fire the mixture. I found this by using electronic cool spray on the module after it starting running rough and it solved the problem. Change the $20 module and issue was solved. I have had the same issue on other HEI equiped cars.
Fro HEIs the pickup and module are separate. When the module fails it will usually limp home but when the pickup fails it will not run.
The Mallory might be failing in the same way. I think it's one unit for the mallory (pickup and module in one).
You could try points if not too easy to change and see if it runs better as a test.
Old Jul 22, 2005 | 02:07 PM
MYBLU71's Avatar
MYBLU71
Thanks Guys,
That was my suspicion. I just didn't want to throw money at something that I didn't have a clue what was causing it. I will check on that piece and see what happens and let everyone know.
Old Jul 22, 2005 | 11:05 PM
Lotus76's Avatar
Lotus76
Just a thought from a different angle...
I had the same symptom and wound up needing a spacer between the intake and carb. I was boiling the fuel when it got hot
Old Aug 21, 2005 | 09:59 PM
MYBLU71's Avatar
MYBLU71
Well, guys I replaced the electronic module in the distributor and still had the same problem. I then bought a Mr. Gasket kit that had 3 plates and gaskets and I installed two of each and no more problem. Thanks for all of your input.
Old Aug 21, 2005 | 10:37 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Am I missing it, or did you not tell us what you replaced the Qjet with? Same carb?
Old Aug 22, 2005 | 03:19 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
What abouta vacuum leak? The choke would come on when cold, but the vacuum leak allowed more air to come get in. Once warm, the choke went off, and let lots of air in, it was just waaay too lean of mixture?
To Stumbles when hot
