Hard Top mounting question
I have a 1969 Hard Top for my 1970. It came with two mounting pins on the back. They look very similar to the soft top pins that "click" into the rear deck lid bezel (latches). Also, it has the usual 3 front latches that attach to the windshield header.
Now, I just purchased a 1970 Owners manual on Ebay...(thought is would be cool to have in the car...) and reading through it I found instructions for the Hard Top install. Pictures show two brackets on the inside of the Hard Top on either side that fasten somewhere under the deck lid??? Also, the instructions state to make sure the nuts and bolts are tight in the rear???? I don't have bolts for the rear... they are latch pins????
Am I reading this wrong? It states there are "8" attaching points for th Hard Top... Can anyone shed some light on this? Pics Maybe? Thank you.
So, pull those pins and use some bolts. I can measure mine tonight if you want the exact size. Also look at Zip or any of the other places and get the side bolts and hardware, you should be able to buy a kit. Check out the first two items on this page. These are the side bolts.
http://www.zip-products.com/Zip/dept...BA87F68D4ABCD8
Orville
NOW, that hardtop was about as factory stock as could be, even the liner was original, I had to reline it...
I had the cone shaped pins in it same as the soft top has....fit in the soft top latch position....had the two tabs on right and left, I never used any bolts....had the bolt hole in center of hatch, still there, and the tab in center of hard top....and 3 latches of course on window header....
I ran that top for two winters up north without any bolts or screws in the rear, stayed on for a trip to Florida and back in '97 or so....prior to my moving south...
bolts are not necessary....
GENE
GENE
I guess you havn't lost the top YET ? after you have one get sucked off then you will change your mind.
Mr Gearhead, If your vette did not come originally with a hardtop, then it won't have the 2 fittings on the sides of the decklid for securing the hardtop. I was able to find bolts at the hardware store that fit in mine (fine thread- not sure exact size) and they really help hold the top on tight! If you aren't able to put bolts thru those holes then I would recommend using bolts in back. On my 68 I have the 3 latches up front, the 2 side bolts, and 2 pins in back (The center hole wasn't used in 68). I have gone back and forth between bolts and pins in back. It is just so much easier to use the pins, and like I said, the side bolts hold the top down tight.
a pic: you can see the receiving hole in the decklid for the side securing bolt. Note that I only have 2 holes for the pins on top of my decklid.
Here is the top I use. You can see the pin and the place where the bolt goes in on the side.
I am using 3" long 3/8x16 bolts with some pretty good size washers to hold the back on now.
there was an outline in the deck paint of wear from hardtop being used, the pins looked as factory as the rest of the top, just as old...no reason they would have switched them.....like I said I sold the top here, after moving....
I drove the car down south on an exploration trip from the DC area, that' 850 miles up to about 90 mph, had the car up to 120 many a time up north with the hardtop on it, winter useage....
the latch held fine, the top never once lifted in the rear or came loose, for that matter the soft top doesn't either....just need adjust the pins/latch mechanism if it does...not rocket science....
so frankly, I think the pins belonged there and bolts are a silly time/effort waster....but you do it your way....have fun...
GENE
"The optional removable hard top is attached at eight points, all reached from within the car. Free all atachment points before removing top. The three header latches are released by pulling down on the handles. The two mounting tab attaching bolts are located below the lower front corners of the rear window. Finally, the three rear bow attachint studs are released by removing the retaining nuts beneath the compartment lid. A special wrench is provided in the glove box to remove any of the attaching nuts and bolts..."
Maybe they changed to pins in 72, mrvette, but I doubt it. I think it was common to add the pins because many thought it was overkill to have 8 mounting points.
Looks like either the pins or the bolts would work just fine and are factory correct depending on year.
wait.... I see a note... hard to read, but looks like 4-20-68
ITEMS 15 & 16 ADDED
where, item 15 is the washer and item 16 is the nut!! So my wild guess is they started out using pins and maybe after a couple of tops flew off they changed to the studs with nuts.
My car was almost completely original when I got it. The hard top came with the threaded rod and large washers installed.
I installed the soft top pins but I am definetely not satisfied with how it holds the top down.
You need to be able to torque (mildly of course) the top down so that it seals the weather strip and also provides a strong mechanical method of holding the top down. To secure the hardtop properly you need to remove the softop and bolt the hardtop on in the 4 (or 5) points and also tightly lock down the front clamps.
The pins are a convenient way of putting the hardtop on for a SHORT SLOW cruise and allow you to keep the softop in the car. If you intend to do any sort of speed with a hardtop on the car then bolt it in.
I never used the side bolts, OR the center bolt in the deck lid, they were all THERE in postion to be used, just ever bothered...
MY reasoning was, WTH, the soft top is secured by the pins, why not the hard top..?? sure enough, properly adjusted like the side windows, the top stay in position, and also the soft top....
BTW, tips on hanging the hard top up on garage ceiling for storage....
I used copper pipe U straps for securing plumbing to studs, and screwed four of them into the ceiling, 4' center, two trusses worth, the front two had a loop of electric romex cable tied looping about a foot down from the ceiling and straight across, better than rope because it retained shape better, all I did was leave the front top latches in the open posiition, hook them to the electrical cord loop above, and then raise the back of the top up to hook similar electrical cord loops around the rear studs, thing hung there about 2 inches off the 8' ceiling and plenty of room to walk....gathered dust is all....
GENE
THANKS for all the input. The top is from a Lemans Blue 1969. A few notes on my car and reason for the top. I didn't get the top for winter/rainy weather. I got it... well.. becasue I think the 2002 Z06s look really sweet with that chopped back window. Soooo, I saw a C3 with a Hardtop and said.. I GOTTA HAVE IT.
Most likely I will remove the pins and bolt the sucker down. Now, if I bolt the back down and use the headers latches... this would seem secure enough? Keep in mind... for some reason... every time I drive it... it takes off from nearly every TRAFFIC light sideways... tires screaming for mercy.... Vaaaa Vaaaa BHAAAAAAAAAAAAAAAAAAAA.......... clunk... WAAABHAAAAAAAAAA......
Another note.... my wife always asks... "Bad enough your fry the tires in the Vette... but must you mimick that sound while driving my SUV?" I tell her... "I am pretending this tank is going to chirp second..." BHAWWWWWWWWWW SCREEEEEEECCCCCHHHHHHH....hahahaha"
Orville
