81 ac hose replacement
Old Jul 24, 2005 | 01:56 PM
Engage's Avatar
Engage
Default 81 ac hose replacement
Can the main ac hose on an 81 be replaced without removing the hood?
If so, what tools are required to remove fitting at condensor?
Thanks.... Barry
Old Jul 24, 2005 | 06:54 PM
DonBecker's Avatar
DonBecker
I have a 76, so this might not be exactly the same.
I had to remove my hood to get the old hose off and put the new one on.
Here's a good one: The AC delco set for my car, the hoses are too thin. By the condensor the hose does a U turn up into the condensor. I had to go to a hydraulic shop and have it fabbed to a different hose. Let me know if you need the specs.
Old Jul 24, 2005 | 08:21 PM
Engage's Avatar
Engage
I was hoping someone would chime in with a better way to do it!
Brand new paintjob on the car and I know that I will never get the hood on and off without something getting scratched..... Should have done it before the paint!!!
Old Jul 24, 2005 | 08:48 PM
71rdster's Avatar
71rdster
I have a 1 piece custom front end on mine that still does not leave enough room to do this work without removal (might work if I was real young and weighed half what I do). You have a lot easier time saving your hood from scratching than I do with the whole front end to move. In your case it might be possible to remove your pass. grille and do some of the work. But I really think its just easier with the hood removed.
Orville
Old Jul 24, 2005 | 09:03 PM
FB#1's Avatar
FB#1
You can do it if you remove your radiator. That may be more than you want to do.
Old Jul 24, 2005 | 11:04 PM
gator79's Avatar
gator79
Default hood removal
removing the hood is not a problem just get a friend to help hold it. one on each side. it might weigh 20 pounds and is easy to handle mine has been off 3 times in the past month (dont ask) things are much easier with the hood out of the way.
Old Jul 25, 2005 | 11:37 AM
adam's Avatar
adam
Yes, it can be done!
But boy is it a pain!! I think I had to open the hood at a specific angle so
that I could put the wrench on and turn, etc.
I.e. not the open position and not the closed position...
Good luck!
Old Jul 25, 2005 | 12:45 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Pretty tough...It is safer to protect the paint on the fenders & put some thin compressed packing foam between the fenders & the hood gap then remove the hood...I think you will thank yourself later.
Old Jul 25, 2005 | 05:30 PM
terry82's Avatar
terry82
i took the the hood off when idid my 82. i used a paint stick and traced a round the hinges .you can use a sharpy or a crayon. went back on the first time .best if you have a helper .
Old Jul 25, 2005 | 10:02 PM
Engage's Avatar
Engage
Thanks for the input guys.... I may have to line the hood gap with thin
foam and get two assistants.... with lots of beer ( after the job is done ).
Old Jul 26, 2005 | 07:12 AM
Gary B.'s Avatar
Gary B.
I managed to remove the a/c hose from my 79 with out removing the hood, I used a crows foot wrench with about 12 plus inches of extension on it. So it can be done. When you are installing the new hose make sure you tie a piece of wire or string on the end to help you pull the hose up to the fitting, and also make sure the fitting has not be bent down. Hope this helps Gary B.
To 81 ac hose replacement
