Lower Control Arm Bushing Removal ?
Old Jul 24, 2005 | 10:27 PM
79vetter's Avatar
79vetter
Default Lower Control Arm Bushing Removal ?
We managed to get the rubber out ok. The problem is the cross shaft between the 2 arms. It cannot be removed even after getting the rubber out. How are you supposed to get a socket on that metal bushing sleeve, and press, when the cross shaft is still there?
The upper c-arm's shaft can be pulled out of the arms allowing you to then place the c-arm onto a drill press and press it out.
I don't have an air chisel to use as suggested by others.
Old Jul 24, 2005 | 10:29 PM
big_G's Avatar
big_G
I don't know of any other way but an air chisel.....
Old Jul 24, 2005 | 11:16 PM
SkunkApe's Avatar
SkunkApe
I brought mine to a shop and said "Do it"...
Best $50 I ever spent.
Old Jul 24, 2005 | 11:17 PM
big_G's Avatar
big_G
Old Jul 25, 2005 | 12:22 AM
Muddywaters's Avatar
Muddywaters
Default outer sleeve removal...
I used wd-40 and had a helper hold mine on top of a vice... I then used a flat punch and walked around the outer sleeves shoulder untill it was out...wasnt too much trouble.
To Lower Control Arm Bushing Removal ?
