Hmmm. Just in case you don't get a quick answer, and if, possibly, you have the gear nearby, just count the teeth & divide into 360. e.g., an 18-tooth gear will have 20 degrees per tooth. Help?
Can any of the engine guys tell me what each crank gear tooth equals in timing degree? thanks for any help! Michael k
360/22=16.36, I just pulled up a Edelbrock gear set on Summit racing and couted the teeth, might not be an Edle set or a Chevy set though so as sugested count the teeth on your gear set and then divide 360 by it.
I got one hanging on the wall right next to me (small block). 18 teeth so 20 degrees per tooth. Remember the crank turns twice for every turn of the cam/distributor so divide by 2 for timing degrees.
Thanks guys, thats too easy, I feel stupid.
My engine just came off the dyno and was not producing the power that it should have, being every thing was new- it came down to mechanical timing. as you watched the #1 piston at (what should have been) ^TDC and timing marks set TDC on the timing chain points, the piston would raise about 1//16 inch or so!
I pulled the crank gear and reset the crank gear and cam timing marks .
Now when engine is rotated from TDC the #1 piston sits (tdc) for about 3 teeth (crank gear)on rotation before dropping down ( as it should) The motor was retarded 1 crank gear tooth and it was fighting its self. I hope that this was a HONEST mistake on the short block builders part! as the short block has a guaranty and that would keep the motor from ever making an over rev! IT COULD NOT rev over 5800-5900 on the dyno and was only getting 390 HP at 16* advance timing with a MSD electronic distributor!
Thanks now it really make sense! i did not factor in the two rotation factor trying to make sense of the 16* w/ the MSD thats suppost to add another 4* advance, 20* minus 10* for the gear tooth makes about 10-12* with the gear set back right!
You guys are good!
