Transmission Problem
Old Jul 25, 2005 | 10:27 AM
matthud's Avatar
matthud
Default Transmission Problem
When I am engine breaking in 2nd gear my transmission kicks out of gear into neutral, or at least out of gear enough to grind the gears. This seems only to happen in 2nd. Like when I am driving down a slight hill and I want to maintain a speed, I take my foot off the gas and try to slow down, after a little bit of this it pops out of gear. It also happened when I was in 2nd slowing down to turn of a main road into my neighborhood, I took my foot off the gas to slow down and once again it popped out of gear.
What is causing this? Is it a linkage problem? Worn gears? Or some kind of detent/interlock issue?
Old Jul 25, 2005 | 10:37 AM
BerniesVette's Avatar
BerniesVette
It could be something else, but it sounds like your second gear syncros are worn, allowing it to pop out of gear when it is under pressure.
Bernie
Old Jul 25, 2005 | 11:08 AM
SteveG75's Avatar
SteveG75
Bernie
Had the same problem. Solved it by going to a Tremec 5 speed.
Old Jul 25, 2005 | 11:22 AM
Scudd's Avatar
Scudd
Congrats the second gear syncros are worn. I think you have two options 1. replace the tranny with a new 5 or 6sp. or get it rebuilt.
Old Jul 25, 2005 | 12:49 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Old Jul 25, 2005 | 01:12 PM
vette fiddler's Avatar
vette fiddler
same problem that I had with an MG Midget when I was a kid. I had to doulble clutch it into gear. That avoided the grind and no one else in the car had a clue the tranny had problems. drove it that way for years. never did bother to fix it.
Old Jul 25, 2005 | 06:12 PM
Techno's Avatar
Techno
He has a 3rd choice, he can rebuild it. Someone just did this a week or 2 ago?
Old Jul 25, 2005 | 06:20 PM
mrvette's Avatar
mrvette
UHHH....on an olde shark, the stock shifter is mounted on the rear cross support, with the rods going forward to the tranny, at least in the munices of '72, and so, make damn sure the shift rods are not outta adjustment, in that with reverse torque the thing is not trying to pop outta gear on account of never actually BEING in total engagement in the first place....
may check engine mounts too....
GENE
Old Jul 26, 2005 | 05:29 PM
vabeachvette's Avatar
vabeachvette
I have a synchro problem going into 3rd, from second and on the downshift from 4th. Picked up a rebuild kit from Medatronics Corp, these guys were the cheapest, I think it was about $160, much better than the $204 and up that are in most catalogs. Oh, by the way, have not yet done mine, waiting until the end of the summer. Good luck.
To Transmission Problem
