Reverse Flow Water Pump
Old Jul 25, 2005 | 05:41 PM
wnmech's Avatar
wnmech
Default Reverse Flow Water Pump
Can anybody out there explain this so called reverse flow water pump? Does the water flow in a different direction. I have been seriously considering converting my 77 over to the serpentine belt conversion and today I spoke to the machine shop that overhauled my engine and heads. He told me that my engine which is a 1978 sb 350 would not be able to work on that engine. He also told me that it would void my warranty. He said lt engines are designed for this pump. I have for the past few weeks made posts and read about all you guys and seen your pictures about the conversions and thought I had it all figured out and today another wrench in the works. I called gulf coast and they are working me up a price on used brackets incase I go back to v belts. Thanks.
Old Jul 25, 2005 | 06:20 PM
big_G's Avatar
big_G
The pump you have is probably from a C-4, LT1. you must use this with LT1 heads. Really a pain to do unless you already have everything from an LT1.. IMO!
Old Jul 25, 2005 | 06:28 PM
Chris Johnson's Avatar
Chris Johnson
You need a reverse rotation water pump, not a reverse flow water pump. On a reverse rotation pump, the water still flows the same direction, but the belt turns in the opposite direction.
Old Jul 25, 2005 | 06:34 PM
SteveG75's Avatar
SteveG75
If your mechanic is confusing a reverse flow (Gen II, LT1 water pump) with a reverse rotation (Gen I, L-98 mid 80's vette) pump, then I would look for another mechanic.
Old Jul 25, 2005 | 06:39 PM
wnmech's Avatar
wnmech
Right now I dont have any water pump on my car. I was in the process of converting my 77 to a serpentine conversion and when I talked to the machine shop maybe I myself did not understand him or he did not understand me but with the serpentine conversion will I be using a reverse rotation or a reverse flow pump? If when you put the serpentine belt on the engine if indeed the pump rotation is reversed over a v belt system would the pump also reverse flow?
Old Jul 25, 2005 | 06:49 PM
Techno's Avatar
Techno
Reverse flow sends the coolest coolant to the heads first and dumps the hottest out the pump, the block.
The 2 radiator hoses are reversed- kind of.
I think this also means you change the thermostat to a different location. I don't know if anyone here is doing this?
Is there?
The other I think is because the belt is wrapping funny on it? The back of the belt is driving I'm guessing so it turns backwards. Like a gear drive compared to a belt drive thing.
Old Jul 25, 2005 | 06:59 PM
SteveG75's Avatar
SteveG75
What you want is a reverse rotation water pump out of an L98 Corvette from the mid-80's. These are Gen I small blocks that have the normal reverse flow and serpentine belts.
If you look at a serpentine drive system, the water pump does rotate opposite a V-belt system.
To Reverse Flow Water Pump
