Engine rebuild kit with stainless inserts?
Old Jul 26, 2005 | 11:01 AM
adam's Avatar
adam
Default Engine rebuild kit with stainless inserts?
Going through my rebuild kit, there is a package of stainless steel inserts.
They look to be two connected plates with a large hole. They say
'break apart here' or something like that.
What are these for? They seem to have clips on the sides to hold onto
something, but I don't understand their place.
This is for rebuilding an 80-85 engine (#207) for my 81.
Thanks.
Old Jul 26, 2005 | 11:08 AM
big_G's Avatar
big_G
Those are heat-riser block-off inserts for the intake manifold gaskets. I would block off the gaskets, as you have an electric choke on your carburetor.
Old Jul 26, 2005 | 12:36 PM
adam's Avatar
adam
Strange - I'll look at them again.
But they have a hole in them. How are they blocking off the gas? Or is one
supposed to add some sheet metal to fully close off the hole?
Thanks.
Old Jul 26, 2005 | 01:08 PM
big_G's Avatar
big_G
That is a restrictor, you can use it as-is.
Old Jul 26, 2005 | 02:06 PM
Techno's Avatar
Techno
I blocked off my exhaust crossover and don't recommend it. Also did it the correct way. The holes in the intake, under carb are plugged along with the gaskets block out.
This has little to do with choke. It heats the fuel mix when cold to make the cold engine run better. Mine runs like sheat until partially warmed up. I now have a manual choke.
To Engine rebuild kit with stainless inserts?
