stroker cam clearance
Old Jul 26, 2005 | 09:43 PM
gator79's Avatar
gator79
Default stroker cam clearance
checked my rod to cam lobe clearance on my 383 and had a little over 52 thousand clearance on cylinders 1,2,5 and 6 is that the cylinders to check? I think I read that somewhere. seems like enough clearance to me. anyone know for sure?
Old Jul 26, 2005 | 11:16 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You're probably OK. Usually you end up slightly grinding the edges of rod bolts on cam side to make sure it all clears. You might want to add a little clearance just incase you change cams later.
JIM
Old Jul 27, 2005 | 12:41 AM
gkull's Avatar
gkull
If your cam to rod clearance is correct for 1 & 2 it is the same for all. That is if your not going to change the cam degree later with an adjustable timing chain
Old Jul 28, 2005 | 12:39 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's all you need, BTW how did you measire it ?
Old Jul 28, 2005 | 01:30 AM
gator79's Avatar
gator79
Default measure
I put 2 long feeler gauges together (aka hacksaw blades) they are 26 thousand each for a total of 52. I put a good curve in them and had a friend turn the motor slowly while I kept it in line with the rod cap and on the lobe. the motor turned over with the two blades between the lobe and the rod cap, so I have at least 52 thousand clearance. maybe not the best way but it worked. there is not much room for your hands and a feeler gauge in there.
Old Jul 28, 2005 | 10:13 AM
mandm1200's Avatar
mandm1200
Did it similiar to this. I was concerned less about the measurement but more concerned about the clearance. When I ordered the rotating assembly from the machine shop they ground the rod bolts that were known to possibly hit. All I had to do was ensure there was adequate clearance when putting it together.
Old Jul 28, 2005 | 10:40 AM
Fevre's Avatar
Fevre
Trick I read was to use masking tape to build up on the lobe the clearence need/desired so when you rotate the eng the rod will hit the tapped lobe(s) if there is not enough clearence.
To stroker cam clearance
