rear lug to long
Old Jul 27, 2005 | 01:54 PM
manco10's Avatar
manco10
Default rear lug to long
Hi Ive got a broken rear lug bolt. Removed caliper, rotor and E brake adj screw. New stud is 1/4" long to install between dust cover and back of spindle. Do I need to pull the spindle or is there a way around it???
Thanks D.
Old Jul 27, 2005 | 01:57 PM
big_G's Avatar
big_G
No, just temporarily deform the dust shield to allow the stud to go in. Make sure that the stud is exactly the same length!
Old Jul 27, 2005 | 11:12 PM
wombvette's Avatar
wombvette
Im not sure that you can move the dust shield much in that area, but you can cut a little off that thing and install it. Wont hurt a thing, unless you got some special lug nuts or something with a thick spacer.
To rear lug to long
