71 Ignition Wiring Question
Old Jul 27, 2005 | 10:34 PM
73Roadster's Avatar
73Roadster
Default 71 Ignition Wiring Question
I have a 71 LT-1 without the TI ignition and I'm not sure how to connect the wiring to the coil.
I believe that the Yellow resistor wire that is combined with the black/purple wire connects to the poisitve side.
Where does the negative side connect in the harness?
and I believe the points simply connect to the positive and negative side.
Thanks,
Ron
Old Jul 28, 2005 | 07:44 AM
pws69's Avatar
pws69
Thanks,
Ron
The negative side of the coil connects to the distributor [points] lead (black).
Old Jul 28, 2005 | 07:48 AM
73Roadster's Avatar
73Roadster
thank you, I will give it a try tonight
Old Jul 28, 2005 | 11:07 PM
71SoCal's Avatar
71SoCal
That's how my '71 is...
Old Jul 29, 2005 | 10:46 AM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Yep
Don
To 71 Ignition Wiring Question
