Crossfire won't start
Old Jul 29, 2005 | 07:03 PM
82XFire's Avatar
82XFire
Default Crossfire won't start
Should the injectors be spraying when the motor is cranking?
I adjusted the TPS and now it won't fire...
Old Jul 29, 2005 | 09:12 PM
big_G's Avatar
big_G
Yes
Old Jul 29, 2005 | 09:52 PM
82XFire's Avatar
82XFire
What's the best location to check the fuel pressure on an 82?
Old Jul 29, 2005 | 09:59 PM
big_G's Avatar
big_G
There is no port, I disconnect the line at the front throttle body, test it there. Keep in mind it will only have pressure for 2 seconds, unless you are cranking it, or it is running.
Old Jul 29, 2005 | 10:21 PM
82XFire's Avatar
82XFire
I'm about the check the voltage on the HEI port of the ECM, any recommendations after that and the fuel pressue check?
Old Jul 29, 2005 | 10:26 PM
big_G's Avatar
big_G
Usually no starts are caused by the fuel pump or a bad ignition module. After that, real tech work begins. Any spark?
Old Jul 29, 2005 | 11:26 PM
MN-Brent's Avatar
MN-Brent
Check for any blown fuses?
Old Jul 30, 2005 | 01:15 AM
82XFire's Avatar
82XFire
Thank you for the input,
Checked the ECM and Ign Fuses, good.
Fuel pump makes all the right noises.
Check for Diagnostic code: It just flashes 12 continuously.
No spray on either injector.
I'm about to backpin the hei terminal on the ecm ,crank it and then mesure that voltage. The AIM has some pretty good flowcharts.
Could starting the car with the TPS way off do anything to keep it from starting again?
Im out for tonight
Old Jul 30, 2005 | 09:55 AM
big_G's Avatar
big_G
No, just set it correctly and go from there
Old Jul 30, 2005 | 02:00 PM
82XFire's Avatar
82XFire
Pulled a wire, there is good consistent spark.
I traced the wiring on the injection circuit and found a bad connector on the upper A.I.R switch. With that fixed, now the fuel pump sounds different when it fires up before cranking and the AIR system is vacumming up.
At the injectors, there is much more persistent drip but still no spray.
The injectors are not making any noise.
No signs of any other pinched or broken connectors, shorts, grounds, burn/melted wiring.
I'm going to see if any codes pop up.
Old Jul 30, 2005 | 02:24 PM
Twin_Turbo's Avatar
Twin_Turbo
the injectors don't make a sound when there's no fuel pressure, your system is not pressurized and with the pump running it means the pump is shot (vanes broke off) or the pump to metering unit hose came off..
Old Jul 30, 2005 | 07:46 PM
82XFire's Avatar
82XFire
Thanks TT, I had hoped you would show up with your .02 +/- .05
I just got back from Autozone with a new 85 Fuel pump.
Getting the old assembly out is proving tricky.
Any particular angle or position make it easier to get out?
Old Jul 30, 2005 | 09:16 PM
82XFire's Avatar
82XFire
Never mind, for future reference have the assembly upside down.
I got it out of the car.
The wiring leads for the 85 pump will require some cutting to work correctly. Do I bypass the condenser-looking thing linked in series with the positive lead to the pump? Its attached to the housing, do I leave it and wire into it as the 82, or do I cut around it and leave it out of the circuit?
I am almost ready to put it back in, just need to sort out the wiring.
Old Jul 30, 2005 | 09:46 PM
82XFire's Avatar
82XFire
Disregard my question regarding wiring. There a tech article over at the Crossfire forum that goes into adequate detail.
Back in it goes, we'll see what happens now...
Old Jul 30, 2005 | 10:21 PM
82XFire's Avatar
82XFire
As its going back in, enough light got into the fuel tank to reveal the source of all my problems. No my girlfriends hair wasn't stuck in the bottom, it was EMPTY! The fuel gauge must have crapped out at 1/2 tank and here I am cranking away wondering why there's no fuel...
More to follow after pump secured and a quick run down to the gas station with the jerry jug.
Old Jul 30, 2005 | 10:28 PM
big_G's Avatar
big_G
This would be an Excellent time to check the fuel gauge sender, while the unit is in your hands!
Old Jul 30, 2005 | 10:53 PM
MN-Brent's Avatar
MN-Brent
Good deal. You get 2 fixes for the price of one fuel guage and 85 fuel pump.
Let us know how it goes.
Brent.....
To Crossfire won't start
Old Jul 30, 2005 | 10:59 PM
lostpatrolman's Avatar
lostpatrolman
No gas?!?!
Old Jul 30, 2005 | 11:14 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
There is a reason they call it the Cease Fire.
Old Jul 31, 2005 | 01:00 AM
82XFire's Avatar
82XFire
It's ALIVE!!!!!
The fuel sending unit got thoroughly cleaned along with the whole intank assembly. All connections checked out. The gauge is now accurately reading the 5 gallons of premium pump swill that I had poured threw a tiny damn funnel.
Turned the key to on and it sounded like somebody flushed a toilet there was so much fuel filling in the injection system.
I cycled it on-off a couple more times until it sounded ready, turned it all the way, and it sparked right up as quick if not quicker than it ever has.
A test drive throught the local mountain preserve is in order but....
ITS RAINING NOW here in Arizona, twice a year and it had to come down tonight........
I'm gonna pull up the radar and see just how long....
Thanks everyone, especially you Big G.
VLTW!
