i'm toying with the idea of two pvc's for more crankcase ventilation. my breather has a tendancy to weep a little oil, and was wondering if a second pvc will help with this problem... the current pvc is new..
I disagree. Pulling a vacuum is a god thing. T PCV's would be great except that manifold vacuum drops to zero at WOT.
The best arangement is a tube that connects to the clean side of the airfilter, just like stock. That way at WOT the fumes get burned and don't mess up the engine compartment
Good point!!
There are valve cover breathers with a hose fitting for that purpose.
If you are running an aggressive camshaft with low idle vacuum, your p.c.v. system may not be able to keep up with the blow-by. Then you may need to plumb 2 breathers, 1 to each exhaust collector tube (only applies to vettes with headers). Or, add a vacuum pump for the crank-case... but that's getting off track for this thread..IMO!
Your missing the point. For there to be flow you have to have the air come in one spot and out the other. Vacuum is the out, so where is the in? A dirty gasket?
If the in (breather) is on the same cover as the vacuum you don't have any vacuum on the other cover. Your vacuum is sucking only through that valve cover. The rest of the engine is bypassed.
Reverse it. Your carb is supplying pressure. The breather is letting it out. flow.
If you pressurize both covers there is no air flow.
If you put a breather on one cover there won't be any pressure in the closed cover since it won't go there. It won't follow the path of most resistance. It will go in the cover and right out the breather.
