Head light problem. Need help fast
Old Jul 30, 2005 | 09:40 PM
dfellinger's Avatar
dfellinger
Default Head light problem. Need help fast
I've got a show tomorrow and tonight when I arrived home, the headlights did not go down when I shut them off. I had to manually assits the right light to come up when I turned them on for the first time this evening and then when I stopped for gas, I did not turn the lights off when I shut the motor down to pump, thus the lights did not go down when I pushed the lights off after the motor was shut off. When I got back into the car, I started it and then pulled the light switch to turn the lights on. Everything was fine until I got home and when I turned the lights off with the motor running, the lights went out but the doors did not shut. Up until tonight I have never have had any problems as I redid all the lines when the rebuild was done. Did I do something wrong and how do I correct it?
Old Jul 30, 2005 | 09:55 PM
big_G's Avatar
big_G
You probably have a vacuum leak in the h/l actuator system. The actuator seals or the vacuum relays may be leaking...
Old Jul 30, 2005 | 09:58 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
When i had that problem, I slipped my hand in between the grille and could manually pull them down. You didn't mention the year but feel around for a threaded bolt running horizontal. Gently tug on it and the covers should close.
Old Jul 30, 2005 | 10:00 PM
Techno's Avatar
Techno
Check to see if the hoses popped off. Mine are old but did have a problem with the wiper motor because of this. That one hose caused the lights to not function too.
Old Jul 30, 2005 | 10:14 PM
dfellinger's Avatar
dfellinger
Thanks Jughead. I just went out to the garage and did what you suggested and it worked perfectly. Damn, this forum is a godsend and you guys are great. Don't know what I would do without the forum and it sure has saved me alot of money and heartache.
Old Jul 30, 2005 | 10:23 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Thats what we're here for.
To Head light problem. Need help fast
