Bolt size: Allen head vs. 12 pt.
Old Jul 31, 2005 | 01:06 AM
SkunkApe's Avatar
SkunkApe
Default Bolt size: Allen head vs. 12 pt.
Can anyone tell me if a 12pt. bolt has a smaller head than a comparable-size (3/8") allen head bolt? I've got a situation where the allen head will not fit in the space where needed.
Thanks.
Old Jul 31, 2005 | 07:45 AM
Techno's Avatar
Techno
Won't the socket be a problem?
Old Jul 31, 2005 | 08:34 AM
Sharky Guam's Avatar
Sharky Guam
It depends of the type of allen head bolt. But the standard allen head 3/8 bolt has a smaller head. Besides getting it in a space where the socket walls interfere won't be a problem with the allen head. When you say 3/8, I am assuming that you are talking about bolt size and not wrench size.
Old Jul 31, 2005 | 10:42 AM
SkunkApe's Avatar
SkunkApe
Yes, bolt-size is 3/8". A thinwall socket will fit. Is there any other type of bolt that has a reduced size head?
Old Jul 31, 2005 | 05:38 PM
Sharky Guam
yes, they make inverted torx head bolts. You can check with ARP or some of the bolt manufacturers to get info on the different sizes and types available.
I am not sure what you are going to be using the bolt for. But ARP makes a stud and nut combo for tight clearance areas.
Old Jul 31, 2005 | 07:03 PM
SkunkApe's Avatar
SkunkApe
I installed a cast-aluminum pan (stock depth, TH-400). The bracket that holds the forward cable (steering wheel interlock?) in place utilizes two 3/8" bolts. The rest of the bolts for the pan are 1/4". B & M supplied the 1/4" allen-head bolts, but not the 3/8" bolts. I tried a standard 3/8" allen-head, but due to the additional thickness of this type pan, the bolt head hits the pan, canting it and preventing it from being started. So...I need something that is 3/8" coarse (16 tpi) that has a small enough head to go in straight.
Old Jul 31, 2005 | 07:05 PM
norvalwilhelm's Avatar
norvalwilhelm
It is a simple matter to cut a cap screw head down on a lathe. Any shop or friend with a lathe can reduce the size of the cap screw. I have done it many times.
Old Jul 31, 2005 | 07:22 PM
SkunkApe's Avatar
SkunkApe
Cap screw? I've heard the term before, but can't picture what it looks like...
I was thinking about grinding down the circumference of the allen-head.
To Bolt size: Allen head vs. 12 pt.
