Engine break- in- oil burning
Old Jul 31, 2005 | 09:13 PM
MikeC's Avatar
MikeC
Default Engine break- in- oil burning
How much is normal amount of oil to burn on a completely new engine on cam break-in (20min @ 2000 rpm)
The engine is a 383 with a scat 4340 forged crank and H-beam rods, 10.5 compression, forged pistons, WP Sportsman II heads. I have a Canton 7 quart pan with a HV pump. The cam is a Comp XE274H ( with all lobes intact so far.){knock on wood}
After my break-in, I checked oil and found it off the dipstick.... added 3 quarts still not on the stick. I drained the oil and found 6.5-7.5 quarts of oil in the pan and probably 0.75-1 quarts in the filter (not yet removed). That means the engine burnt 1-2 quarts on inital fire up. Is this normal?
Has anybody had trouble with this oil pan and dipsticks? I'm running a factory dipstick and an MR gasket chrome tube that is ~ 1.5" shorter than than the factory one.
Old Jul 31, 2005 | 09:19 PM
1978SA's Avatar
1978SA
No, defintely not normal for a breakin. You *had* to see smoke coming from the assend, if you lost that much oil in 20 minutes.
Old Jul 31, 2005 | 09:55 PM
MikeC's Avatar
MikeC
Yeah I saw smoke on start up and for about 4-5 minutes run time but not that much. It pretty much quit after that (at least no visible smoke).
I would think that burning that much oil in the cylinder would cause sparkplug fouling.
Old Jul 31, 2005 | 10:01 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Did you put 7.5 litres ( 7 for oil pan. 1/2 for oil filter ) when you first started it up ? Did you look on dipstick where the oil level line was and scratch a mark on it ?
If you did put that much in and added 2 or 3 qts then it loolkes like it burnt it but I doubt that is what happened, some kind of mistake counting oil you first put in or a distick problem is my guess
Old Jul 31, 2005 | 10:08 PM
pauvil's Avatar
pauvil
oil burn is normal as the rings need to seat. BUT NOT THAT MUCH!!!! WHAT ARE YOU READING FOR PRESSURE ON THE GAUGE?? maybee missing a plug (internal or external), something is not right, CHECK THAT PRESSURE!!! are you smoking like an SOB?? out the exhaust??
Old Jul 31, 2005 | 10:38 PM
MikeC's Avatar
MikeC
I am sure I put enough oil in it..... thats what troubles me.
Yeah its smoked for a bit.... but not enough to burn that much.
I have a small video taken from my dig camera if someone can host it, it shows the smoke coming out the pipes.
To Engine break- in- oil burning
