AC - outside air vs inside air?
Old Aug 1, 2005 | 10:43 PM
flynhi's Avatar
flynhi
Default AC - outside air vs inside air?
I came across a post in my AC file for my 71 vert that suggests:
1. Disconnecting the vacuum actuators on the fresh air flapper and MaxAC door.
2. close and seal the fresh air door with silicone
3. remove the MaxAC door
4. plug vacuum lines
The recirculates inside air all the time and improves the AC performance.
Has anyone tried this? If so, what were the results?
Old Aug 1, 2005 | 11:02 PM
lostpatrolman's Avatar
lostpatrolman
Wouldnt good sealing new seals be just as effective?
Old Aug 1, 2005 | 11:36 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Also why butcher the car needlessly? The AC should be able to freeze you out if it is properly charged and working right. It is very nearly the same system used in full sized Chevy station wagons!!
Old Aug 2, 2005 | 12:04 AM
71SoCal's Avatar
71SoCal
I pinned the fresh air door shut on my '71. You do lose the ability to get fresh air in the car, but I think it's worth it. If I need fresh air, I'll open a window!
The door's flap had a tear in it, and it's been discontinued, so I closed it off.
There's actually another thread running around titled "Interior still hot..." that I started a few weeks ago. I recommend checking it out. It's received a lot of great info.
Old Aug 2, 2005 | 10:34 AM
flynhi's Avatar
flynhi
Lost Patrol and StickShift,
I've not been able to find a replacement rubber fresh air seal and mine's now 35 years old and deteriorated. I've read that even when new, air pressure at the cowl when at speed causes it to leak.
I have plenty of fresh air with the vert so I'm really not losing anything by just continually recirculating interior air.
I don't know that this modification is any more butchering than other performance related mods that we all have made.
Old Aug 2, 2005 | 10:53 AM
Pete76Shark's Avatar
Pete76Shark
If you do this and your A/C is working properly you run the risk of freezing up the evaporator cause it is running on max A/C all the time.
Only 2 ways to prevent this. first is to allow fresh air into the evaporator and the second is to allow hot water thru the heater core (turn the heat on).
If you A/C is not running 100% then you might not run into this situation.
Old Aug 2, 2005 | 12:47 PM
markdtn's Avatar
markdtn
I've not been able to find a replacement rubber fresh air seal and mine's now 35 years old and deteriorated....
Dr Rebuild has them (8844130). Take flapper door out, drill out rivets, install new rubber, peen new rivets, re-install door.
Old Aug 2, 2005 | 01:21 PM
rihwoods's Avatar
rihwoods
...my A/C does not work on Max..and my fan does not work on "high" speed....and I have disabled my heater...so I have no intention of fixing those items now...except the heat on pass side....getting real close..insulating exterior footwells...rarely need A/C..just run it to keep seals lubricated..
Happiness is (in my case) tops off,windows down, driving the thing...
But,for those who want to get tangled up in ventilation....
http://home.comcast.net/~chadwick.ro...entilation.htm
Old Aug 2, 2005 | 01:51 PM
flynhi's Avatar
flynhi
Pete67shark - good point, I have a freeze protection switch that disengages the compressor if the evaporator begins to freeze up.
Markdtn - I have ordered the Dr. Rebuild repair kit but it's for the interior air recirculation door at the passenger's feet. The problem I'm having is witth the rubber like flapper on the cowl fresh air opening. I cannot find a source for these.
Old Aug 3, 2005 | 08:05 AM
markdtn's Avatar
markdtn
OK-yes, those are a bear to find. I misunderstood your description. Maybe the Dr will make those too someday. If I see him at Carlisle I'll ask him.
Old Aug 3, 2005 | 08:24 AM
71406's Avatar
71406
You need to fresh air to defrost or defog your windows. If you permanently seal off fresh incoming air if will be difficult in certain weather conditions such as rainy days or cold day when the windows are closed to keep your windshield clear. To me this is a safety issue and for this reason would no do it.
Old Aug 3, 2005 | 09:31 AM
flynhi's Avatar
flynhi
Good point, Paul.
Down here in Austin we don't have much cold weather and I rarely drive in the rain so I think I'll be OK with limited defog.
Old Aug 3, 2005 | 11:03 AM
71SoCal's Avatar
71SoCal
You're right...it's tough to defog with interior air. I wasn't too concerned about that functionality since my car isn't a daily driver, and it doesn't come out of the garage unless it's sunny out.
Old Aug 3, 2005 | 11:24 AM
Hef's Avatar
Hef
Default Max Air
Regarding Max Air: I recently started using my Air Cond and I noticed when I go to Max Air nothing changes far as I can tell. Can someone tell me what should happen when you switch to Max Air from norm Air? Thanks,
Hef
79 L-82 with aux fan
Old Aug 3, 2005 | 11:25 AM
flynhi's Avatar
flynhi
I've seen foam blocks in a couple of the catalogs that plug holes in the frame below the firewall. Anyone know where air entering through these openings exits? Any chance it is getting into the air plenum?
BTW, I have now used about a half a roll of rope caulk filling cracks and holes in the AC ductwork.......
Old Aug 3, 2005 | 11:41 AM
flynhi's Avatar
flynhi
Hef,
The max air door at the passenger's right foot should open and the cowl outside air door should close.
Trace the vacuum lines and test the actuators with a MityVac to see if they are functional. If they are and they do not work when the selector is rotated, you have a vacuum problem. If other functions work, you have a rotten or deteriorated vacuum hose to one actuator or the other or both.
Old Aug 3, 2005 | 06:23 PM
BerniesVette's Avatar
BerniesVette
There is a book called "Air Conditioning Strategies for the 63-82 Corvette". It is a great book and well worth having to make your Vette cool and comfortable and explain the pecularities of the the C3 A/C system; and it is a strange system compared to others.
The book is approx. $20.00, and after having bought and used it, I would do it again!
Send $19.95 to Prestige Publishing, P.O. Box 2786, Grapevine, TX 76099-2786 and they will ship the book to you postage paid. Or you can buy it from one of the vendors.
I used the suggestions in the book and made my '79 a comfortable car to ride in. Hope this helps.
Bernie
Old Aug 3, 2005 | 09:19 PM
flynhi's Avatar
flynhi
After caulking holes and seams in the air plenum, caulking ducts and revising vacuum lines so that the fresh air flapper is always closed (recirculating inside air)
Test Drive Results: Supply air 6 degrees colder on 95 degree day.
Not bad for a $4 roll of caulk.
To AC - outside air vs inside air?
