Turn signal switch bad???
Old Aug 2, 2005 | 04:31 PM
68 Blues's Avatar
68 Blues
Default Turn signal switch bad???
Hello,
I was driving my 68 vette the other day and noticed the turn signals werent working. After making sure that the brake lights, parking lights, flasher were all good, the only thing I am left to assume is that the turn signal switch has gone bad. Does anyone agree?
I looked around at a couple of the online sites for a switch, and it appears that 68 must be the odd ball. Two places were out and one other doesn't show one. Does anyone know who or where I might be able to find one of these for this car?? Thanks for any help you can offer!!!
Old Aug 2, 2005 | 04:34 PM
jaycjackson21's Avatar
jaycjackson21
On my 75, there are separate flasher units for the hazard lights and the turn signals - make sure you are looking at the correct one. There is also a fuse (in addition to the flasher) - if you havent already, check that too before you mess with the switch.
Old Aug 2, 2005 | 04:56 PM
CGGorman's Avatar
CGGorman
Oh boy... Sit down, then click below...
http://forums.corvetteforum.com/show...lle&forum_id=3
Old Aug 3, 2005 | 08:22 AM
68 Blues's Avatar
68 Blues
man,,,,I guess I'll check all of the simple things first! Thanks for all of your help!!
Old Aug 3, 2005 | 08:25 AM
68 Blues's Avatar
68 Blues
Does anyone know if this is the case for my 68? Im sure this would be too easy!!!
Old Aug 3, 2005 | 09:13 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Two flasher modules- one on fuse panel and the other under the passenger-side of the dash (next to ball vent outlet.) The one on the passenger side is the likely culprit.
Fuse in panel.
Good luck- hope it's just a plug and play module.
Old Aug 3, 2005 | 02:38 PM
68 Blues's Avatar
68 Blues
Thanks guys, It'll be this weekend before I can look at it, but I'll check these things first!
Old Aug 3, 2005 | 08:11 PM
Techno's Avatar
Techno
If it is the flashers just swap them. Should reverse the problem.
Old Aug 3, 2005 | 11:28 PM
pef427's Avatar
pef427
What he said...
To Turn signal switch bad???
