81 Corvette ac
Old Aug 3, 2005 | 01:34 PM
Engage's Avatar
Engage
Default 81 Corvette ac
Should the electric cooling fan at the rad kick in when you engage the ac on hi blower speed and max ac?
Thanks... Barry
Old Aug 3, 2005 | 01:55 PM
marioncole's Avatar
marioncole
I converted my 74 over to electric fans and the AC shop had me wire the fans to come on when the AC is on. Without the fans staying on the head pressure on the AC compressor would rise and then fall back down when the fans kicked in. To keep head pressure low, I installed a trinary switch in the high pressure line and uise one set of contacts to turn on the fans.
Old Aug 3, 2005 | 03:11 PM
Schwee's Avatar
Schwee
My '81, with factory AC, does not have an electric fan at the rad.
Maybe yours isn't stock?
Old Aug 3, 2005 | 05:06 PM
Engage's Avatar
Engage
All 81's should have them.
http://vette81.tripod.com/specs.html
Old Aug 3, 2005 | 05:35 PM
PhotoVette1's Avatar
PhotoVette1
The aux cooling fan for an '81 uses a temperature switch mounted on the drivers side forward on the engine. I believe it comes on at 228F or so.
Old Aug 4, 2005 | 12:57 AM
terry82's Avatar
terry82
my fan has never needed to come on .with or with out ac on .but i have checked it to see if it worked .
To 81 Corvette ac
