Msd 6al
Old Aug 3, 2005 | 07:23 PM
blackbeauty74's Avatar
blackbeauty74
Default Msd 6al
Could you guys who are using tha MSD 6AL with HEI tell me What ignition coil you are using.
thanks
Old Aug 3, 2005 | 07:29 PM
EDDIEJ82's Avatar
EDDIEJ82
MSD Blaster SS...I like it because it is small and I can mount it sideways on my firewall.
rcread's Avatar
rcread
MSD Blaster 2 the last seven years. It's always worked fine.
Old Aug 3, 2005 | 11:05 PM
carl a's Avatar
carl a
i run the dry type coil mounted on the intake, had the oil filled blaster 2 coil also mounted there and it burned out a winding because a air bubble forms when these type coils are not mounted vertically............. this back fed the msd 6a box and fried it, now i run the 6al and the dry type coil,,the gentleman at the speed shop caught it..i should have being a electrican for 26 yrs we always pour a level concrete pad to set a transformer on,,,LEVEL THERE OIL FILLED--------------------------photo shows location of 6-al box and dry coil on intake mount-----------------------
To Msd 6al
