Which intake to use
Old Aug 4, 2005 | 09:10 PM
red2blk's Avatar
red2blk
Default Which intake to use
i'm using ZZ4 alum.heads 63cc.L98(1989) engine block,with Crane gold aluminum 1.5 roller rockers,Comp cam -hydraulic lifters.I need help on finding the right TPI intake to use.
Old Aug 5, 2005 | 12:11 PM
red2blk's Avatar
red2blk
still need help.
Old Aug 5, 2005 | 12:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Maybe post in the C4 section, mostly carb experts here
Old Aug 5, 2005 | 02:04 PM
Boofers's Avatar
Boofers
"Experts" is a bit of a stretch
Old Aug 5, 2005 | 02:20 PM
1970-Bronze's Avatar
1970-Bronze
Well, I guess the question in my mind is hood clearence or are you just looking for recommendations?
TPIS Big Mouth and Large Tube runners make some great torque and decent power. SuperRam makes more HP and slightly less torque.
Your RPM range will tell you the correct choice.
Old Aug 5, 2005 | 02:22 PM
Fevre's Avatar
Fevre
Any TPI off a vette will work, it will have the correct center bolt hole angles but you can still use an F body TPI, you have to elongate the the holes.
Just remember you will limit your hp out put with a stock TPI intake but it will give great torq,
To Which intake to use
