82 Crossfire Idle
Aug 5, 2005 | 08:16 PM
St. Jude Donor '15
82 Crossfire Idle
Can Anyone Tell Me What The Proper Idle Rpm's Should Be On My 82? Thanks
Aug 5, 2005 | 08:18 PM
St. Jude Donor '05-'06-'07-'08
Aug 5, 2005 | 09:52 PM
I would think around 900 would work either way, stick/auto.
Aug 5, 2005 | 10:14 PM
Quote:
Aug 5, 2005 | 10:33 PM
Were no sticks in 82 ya tard
All autos
Aug 5, 2005 | 10:36 PM
The idle program on the pcm is set for 600 rpm at operating temp...any higher means the anti-tamper welds have been tampered with, or the thottle bodies may have other issues.....
Aug 5, 2005 | 10:43 PM
hey gr8whte, daaa! yourself, any 350 Chevy any combo would run at that, just a starting point, I don't give a damn what they made that year!!
Aug 5, 2005 | 11:09 PM
Damn dude chill out, or I'll come over there and give you a spankin
Aug 5, 2005 | 11:12 PM
Can I watch?
Aug 5, 2005 | 11:30 PM
Quote:
Originally Posted by big_G
Can I watch?
Yes u can. But i gotta charge admission. Ineed a new carb for the 78
Aug 6, 2005 | 01:22 AM
Quote:
mine is about 600 in gear .in park it will verry some 800-900 rpm. when cold the computer makes it run some higher .
Aug 6, 2005 | 09:06 AM
I agree with Terry
Aug 6, 2005 | 09:43 AM
800 in park and 650 in drive is what I get.
Aug 6, 2005 | 10:03 AM
If your running higher, then you may have a vacuum leak somewhere like the EGR, MAP sensor, brake power booster or headlight system. Start plugging these temporarily by hand and see if your idle drops.
It is also a possibility that your coolant temp sensor is going out on you. Replace that one and see what happens.
Brent....
