Need help with Parking Brake!!!
Old Aug 5, 2005 | 10:54 PM
JBRIDDLE's Avatar
JBRIDDLE
Navigator
Default Need help with Parking Brake!!!
I set the parking brake to check to see if it worked on my 1977. Now when I drive down the road I hear a grinding noise like the brake is still engaged. I think it is stuck how do I get it unstuck???????????
Old Aug 5, 2005 | 10:58 PM
big_G's Avatar
big_G
Probably something inside the p/b assy. has come apart, like the shoe return springs. Also, the cable may be frozen and not releasing...
Old Aug 5, 2005 | 11:01 PM
JBRIDDLE's Avatar
JBRIDDLE
Navigator
what is the best way to fix it?
Old Aug 5, 2005 | 11:03 PM
big_G's Avatar
big_G
You will need a shop manual for that, it can be somewhat involved...do a forum search, I'm sure someone has posted on this rebuild process...G/L
Old Aug 6, 2005 | 12:46 AM
FeedVaal's Avatar
FeedVaal
Order the stainless kit from one of the vendors and use lots of anti-seize. Search corvettefaq.com for the dental-floss spring trick, and you'll be good to go.
To Need help with Parking Brake!!!
