Small Block Rear Seal Replacement
Old Aug 6, 2005 | 09:03 AM
7T3C3TTZ07's Avatar
7T3C3TTZ07
Default Small Block Rear Seal Replacement
Someone suggested to me that the rear oil seal could be replaced without removing the engine from the vehicle. This seems a little too easy to me. The particular oil leak is the only engine problem I have right now and I would like to avoid pulling the engine just for this. I am willing to tackle the job. What is involved? Should I use the stock GM part or is there a better after-market part?
Thanks,
Ken
Old Aug 6, 2005 | 09:24 AM
FeedVaal's Avatar
FeedVaal
I've done it once on a Ford truck with the engine in. Not a big deal for a wrencher. You'll have to pull the tranny of course and oil pan which means dropping the steering arm to get it out of the way. Once you've pulled the clutch and flywheel you'll need to loosen the bearing caps enough to drop the crank about 3/8" to provide clearance to the seal. the top seal needs to be inserted veeery carefully to avoid sculling the edge and rendering all this work in vain. I offset the top seal about 1/8" and used a little RTV on the mating surfaces. Now is also a good time to inspect your rod and main bearings and replace if they show wear.
Stock replacement part is fine.
Old Aug 6, 2005 | 10:01 AM
moosie982's Avatar
moosie982
Default are you sure?
Hi, I did this job quite a while back and I dont remember pulling anything but the oil pan, I was thinking it was very close quarters to work in but I know I didnt pull the trans or the bell housing, this was on a '71 LT-! conv that I once had. As suggested I did offset the mating surface of the seal when I put it back together etc. Good luck Peace,,,Craig
Old Aug 6, 2005 | 10:52 AM
FeedVaal's Avatar
FeedVaal
Good to know its possible with the flywheel in place. I imagine the PITA factor of pulling all those parts would be offset by the tight space you'd have to deal with. Ain't a easy chore either way, but do-able.
Old Aug 6, 2005 | 11:08 AM
rihwoods's Avatar
rihwoods
A friend just did this on his Cherokee,along side the hwy in Yuma...he had to pull tranny back a little...used rocks to prop tranny in place..and used a coat hanger to feed seal in ...
He had an automatic...
Old Aug 6, 2005 | 11:43 AM
big_G's Avatar
big_G
Thanks,
Ken
You just need to drop the pan on a 1985 or older block....G/L
Old Aug 6, 2005 | 12:57 PM
surfshark's Avatar
surfshark
I just dropped the pan to replace my rear seal. Didn't have to pull anything else. It's been a little while and I can't quite remember if I had to loosen the mounts, and lift the engine a little to clear the pan. (It seems like I've done that so many times for so many tasks). It's not a horrible job, but it takes a bit of time. A helpful friend always makes a big difference with any job. Good luck.
Old Aug 8, 2005 | 02:37 AM
stickboy's Avatar
stickboy
I've done it. Just drop the pan and remove the bearing cap. Be careful installing the new seal. I had to do it 2 times. The first one came with a gasket set and didn't come with plastic tabs to protect it when I pushed it in. Needless to say it leaked worse than to old one. I got another seal from the local parts store and it came with a plastic tab that protects the seal as you install it. Also don't over tighten the oil pan as you put it back on
Old Aug 8, 2005 | 11:14 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Just did this two weeks ago. Drop the steering (easiest to do if you simply unbolt the idler arm from the frame) so the oil pan can be removed. Pull the oil pump, and the rear main cap. Once the cap is off the lower cap seal is no problem. Hardest part is getting the upper seal to slide around the crank. I used a very small screwdriver (an old oil dipstick works well too) to loosen the seal as far up as I could without damaging the crank journal. Then tap on one side of the upper seal using a brass drift and the seal should roll around the crank enough for you to pull it out with needle nose pliers. Sliding the new one in is cake (make sure you have it facing the correct way). Then reverse the rest of the parts and you're in business. Don't forget to lightly lube the seal lip and get yourself a one piece pan gasket if you can (search other posts on this topic), it will make you life easier in the long run.
Old Aug 8, 2005 | 11:30 AM
78pacer's Avatar
78pacer
Gheeesh! I thought replacing wiper blades in an AutoZone parking Lot was the pits! He musta been dumping out oil like he had a rock thrown threw his pan.
Mike
Old Aug 8, 2005 | 11:55 AM
rihwoods's Avatar
rihwoods
Mike
He was 12 miles east of Yuma..he told me he botched the first seal and had to hitchhike back to town for another one..I offered to go help(170 mile drive) but he said he would be ok...it was 112 F there...
Old Sep 8, 2005 | 05:19 PM
82XFire's Avatar
82XFire
What about the 1982 block?
Old Sep 9, 2005 | 02:14 PM
82XFire's Avatar
82XFire
duh- need more coffee post says 85 and earlier
Old Sep 9, 2005 | 02:32 PM
Edzred72's Avatar
Edzred72
Exactly how it's done on an older small block. Just be sure to torque the bearing cap & oil pump to specs. You might consider replacing the $1.00 plastic oil pump shaft connector while your in there.... Carefull of the oil pump pick up so ya don't bend, twist, or damage it.
Eddie
Old Sep 9, 2005 | 04:33 PM
82XFire's Avatar
82XFire
Should timing cover seal/gasket get replaced just for good measure?
Old Sep 10, 2005 | 03:13 AM
tigers123's Avatar
tigers123
Default Rear main seal
Being an old line mechanic [over thirty years ago] the drill is that most oil pans come off and you service the seal in the car. Exception was the Chevelle. You had to pull the motor. That being said we were required on Warranty work to plastigage the rear main. If the clearance was too great you put in .001, .002, or.003 rear main bearings along with the rear main seal. This tightened the bearing clearance and helped to control oil leaks as well. These different sized rear mains were available from GM, but I don't know if they still are. But once again you have to pick the bearing size based on the plastigage reading. Also we used silicone spray and or lubriplate to coat seal. Where you lose most seals is from not lubricating the lip. On start up against a dry seal you will "burn the lip" [glaze actually] the seal and you are no better off than before you decided to fix the leak. The reason I know all this, is a lot of customers would not put up with an oil spot in their driveway when a car was under warranty. So you learned fast what worked and what didn't
To Small Block Rear Seal Replacement
