Just got a 78 L82 that was in storage for 12 years. Everything has been brought up to good order with the exception of the brakes, they are making me crazy. Brake reservoir rubber seal was gone, master cyl full of crud and calipers leaking. I replaced the master cyl, vaccume booster, brake proportion valve, and all callipers. Have bleed all calipers and master cyl with power bleeder. With out the engine running has good hard pedal. Start the engine and the pedal fades to the floor. Bleed some more and still same problem. Everything but the hard lines have been changed and there are no fluid leaks anywhere. Any ideas?
If the pedal goes to the floor, there is still air in the system somewhere. Did you bleed both halves of the rear calipers? Did fluid flow freely from all bleeders? Does the brake warning light come on when the pedal is depressed? The pedal travel should be about 21/2 inches with the engine running.
I followed the procedure in the book where I bleed the right rear outside, rt rear inside, lf rear outside, lf rear inside, rt front and then the lf front. Same procedure each time. While bleeding each position I tapped on the calliper with a small hammer to dislodge any small air bubbles. On the final 3 or 4 rotations I had nothing but fluid. I used a transparrent line in a bottle of brake fluid just incase of air return. The brake pedal rod to the vaccume booster was the same length as the stock one removed and has no stop nut for pedal adjustment. When the engine is running and in gear I can initially stop the rotors (car is on blocks) but as the pedal fades the rotors start to slowly turn(loosing clamping pressure). So far I have run about 2 gallons of brake fluid thru the system. ????
The only thing I see missing from your list of replaced parts (besides the hard lines) are the flexible hoses at each corner. Although I would not expect them to release pressure as you've indicated is happening. They can contribute to a spongy pedal or sticking caliper, but without leaking, will hardly release this much pressure.
By-the-way, because you replaced your master cylinder doesn't mean it isn't the problem, particularly if you replaced it with a rebuilt. Assuming there are no leaks, as you've indicated, it really sounds like the master cylinder is the culprit. The only time I've had a pedal go to the floor without losing fluid is when the master cylinder was leaking internally.
You might want to try a new one, or at least a known good one.
Good luck... GUSTO
I agree...and bench bleed it really really well. It took me about 40 minutes on the bench before I got all of the air out. Some instructions that come with MC's say to pump until you do not see any bubbles in the clear bleed lines that they normally supply...but do not stop there. Alternate between tapping the side, short and long pumps until ALL those small air bubbles are gone from down inside the unit. Also...go with a new unit.
I have the same problem as Ken.Replaced entire system 3 masters,SS hoses,about a gallon od Dot 5 fluid thru the system,still no pedel with vacum assist on.any other suggestions?
Rob ***
The system is designed to be relatively independant between front and rear. If you have no brakes at all then it has to be one of the common elements. 1. Master Cyl. 2. Booster (you will have brakes without the booster, just not power brakes) 3. Proportioning valve. Look at these items first!!
The booster cannot affect the hydraulic brake system, only assist it. Without the engine running, the brake pedal should only move about 1/2 in., once the residual booster vacuum is bled off.
Ken as I said in an earlier post I had the same situation as you I finally solved it this way.I removed the front line,and installed the plug in the master.The pedel was a little firmer but still too soft.I then removed the rear line,and installed the plug.The pedel was rock hard with and without assist.(no air in the master).I then installed the rear line,and gravity bled the rear in this order.LTinner,LTouter.RTinner,RTouter. Frequent smacks wither a ruber mallot helped keep the bubbles moving.when I had a hard rear pedel with the front plug instaled in the master,I moved to the front.the front for some reason required more effort,but I finally,have a hard pedel with assist.Hope this helps.
Rob
