69 Pwr Steering problem (Jim)
Old Aug 8, 2005 | 09:33 AM
Surfer69's Avatar
Surfer69
Default 69 Pwr Steering problem (Jim)
My power steering valve is leaking bad and needs to be replaced. I'm letting the pump run dry and still driving around basically with manual steering. My question is, will the pump or anything else in the system be damaged if it runs dry and I drive like that?
Old Aug 8, 2005 | 09:42 AM
big_G's Avatar
big_G
You will, if you haven't already, burn up the pump. Remove the belt until you can repair the system...G/L
Old Aug 8, 2005 | 10:10 AM
Gordonm's Avatar
Gordonm
Get that belt off as soon as possible. You'll be lucky if you have not burned up the pump.
Old Aug 8, 2005 | 03:42 PM
V8yunkie's Avatar
V8yunkie
Default Power steering
Sorry guys, but driving around with no pressure on the power steering system is about as bad as ruining the pump with no oil!
You will have excessive play in the steering as the pivot bolt in the valve will first move from one side to the other before moving the relay rod. I would only do this in case in emergency to get back home (and drive very carefully). But this will most definitely ruin the valve completely.
BTW, DO replace the valve with a NEW (not rebuilt) unit. And forget about the rebuild kits. This is a fix for 1 year (if at all) and then the leaking starts again. Fix it once and forever.
Regards,
Thomas
Old Aug 8, 2005 | 04:01 PM
Surfer69's Avatar
Surfer69
Thanks. Looks like I'll keep fluid in until I get the new part.
Old Aug 8, 2005 | 04:05 PM
Jim Shea's Avatar
Jim Shea
In defense of the rebuilt control valves, you may note that several major Corvette suppliers warranty their rebuilt valves for five years. The new ones only for one year. That would seem to indicate confidance in the rebuilt type.
Jim
To 69 Pwr Steering problem (Jim)
