tranny mount & speedo seals
Old Aug 10, 2005 | 06:55 PM
JohnG76's Avatar
JohnG76
Default tranny mount & speedo seals
does anyone know if its possible to change the tranny mount on a 73 small block auto without removing the frame crossmember
and
if the repalcement speedo seals are supposed to go in without a press
thanks
John
Old Aug 11, 2005 | 12:31 AM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
I'm guessing you don't want to drop the crossmember because you don't want to disconnect the exhaust??
It might be possible to change the mount without dropping the crossmember by simply jacking the tranny up as high as it will go into the tunnel, but be careful not to jack it up too much because you could damage the fiberglass floorpan/tunnel.
If that doesn't give you enough room to switch the mount then you will have to unbolt the crossmember, but it shouldn't be a problem to allow it to hang on the exhaust pipes while you work on the tranny mount.
Not sure what tranny you have, but the speedo seals on my turbo 400 are just o-rings. No press needed.
