mech advance only getting 16 degrees
Old Aug 12, 2005 | 12:57 AM
Riley's Avatar
Riley
Default mech advance only getting 16 degrees
I put in new springs in and then mechanical advance is free, but i only seem to get 16 degrees mechanical advance. I have it set at 20 at idle and 36 full mech and 52 with vacumm. I just thought that 20 was abit much. but the car seems to like it as no pinging is noticed. I am i missing somthing or is this ok.
Old Aug 12, 2005 | 01:50 AM
Z-man's Avatar
Z-man
Is the 20 degrees measured with the vacuum hose disconnected and lines plugged? It sounds like the 20 is with the vacuum lines on.
Old Aug 12, 2005 | 08:14 AM
Boofers's Avatar
Boofers
What RPM do you get 36 degrees at? Maybe you need some lighter springs; does the advance increase beyond 3000RPM?
How to set timing for peak performance by Lars
Old Aug 12, 2005 | 08:15 AM
TJ76's Avatar
TJ76
That is the same as mine. And it runs very well. And it is consistant with Lar's paper.
TJ
Old Aug 12, 2005 | 09:29 AM
Retro78's Avatar
Retro78
TJ
Mine too...I think you are good
Old Aug 12, 2005 | 12:47 PM
BigBlockk's Avatar
BigBlockk
If you're getting only 16 degrees out of your centrifugal advance there may be a advance limiter bushing installed in the distributer. Or possibly the slot has been welded up to limit advance.
BigBlockk
Later.....
Old Aug 12, 2005 | 12:55 PM
Riley's Avatar
Riley
yes the vacuum line is plugged and all mech is in by 2700 rpm. It performs very well like this so i guess i will leave it as is. Ran a 13.452 at the trach with 3.08 gears and treet tires so i guess it is not doing to bad. Well at least i think 13.4 is repectable..
Old Aug 12, 2005 | 04:20 PM
Stewart's74's Avatar
Stewart's74
reading Lars' paper was a big help for me....
Old Aug 12, 2005 | 06:37 PM
Techno's Avatar
Techno
Don't forget to read the part about modifying the mechanical advance and the part about the vacuum advance.
Not that you have to but it is good info.
Old Aug 13, 2005 | 07:46 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Changing to lighter springs may have your centrifugal starting below idle rpm. If that's the case, a few degrees would already be added by idle. You can check by lowering idle as low as possible and checking timing. In any case, you've got 36º total and no starting problems so it sounds good to me.
To mech advance only getting 16 degrees
