Rear gears - recommendations/cost
Old Aug 12, 2005 | 11:44 AM
72Tornado's Avatar
72Tornado
Default Rear gears - recommendations/cost
OK, so I really want to replace the rear end gears in my 72 L-48. I'm still not 100% sure what I have in there but using a rear-end gear calculator, it seems I have 3.08's or taller (read: worse), assuming my tach is reasonably accurate. My brother took the jack to St. Louis so I don't have a way to check for sure Once school starts in September I'm hardly going to be doing any highway driving (not going to get to do much driving during the school year at all, actually ), so highway RPM won't be much of a concern at all. That being said, what would you guys recommend as far as what to swap out the gears for? I was thinking 3.43's seem pretty reasonable, or should I even go as short as 3.73's?
Also, how much can I expect to pay for a job like this INCLUDING the gears themselves?
Thanks in advance guys
Old Aug 12, 2005 | 12:09 PM
GTR1999's Avatar
GTR1999
If you have an original automatic car you should have 308's, a WR 4 spd and you'll have 336's. Ratios available are 273,308,336,355,370,373,390,411 Of these not all are available from the same sources.
I only use Tom's US Gears and they run about $275-300 depending where you buy them. Add in about $600 for a standard rebuild and another $50 UPS one way.
I charge about $1,200 depending on the required work, (less UPS), for a full custom blueprinted rebuild with new gears. If you want to build one yourself I have a complete setup less gears ready to build.
You should think about how you're gong to drive the car, with gas going over $3,00 gallon those 308's might not be all that bad.
Let me know if I can help.
Gary
Old Aug 12, 2005 | 12:13 PM
rihwoods's Avatar
rihwoods
Go for the 3.70's...great two lane twisty gears...
Old Aug 12, 2005 | 12:55 PM
Gordonm's Avatar
Gordonm
Gary
Gary is right on. I got a set for arouind 280 this winter and installed them myself. The labor he quoted is pretty much dead on for someone to do the job correctly. I stress correctly. If someone quotes you 200 pass on it, you will be doing it again. You want to get this right the first time. It takes time and patience to do it right.
I have the 3.73s in mine but I have a Tremec with a .68 OD.
Old Aug 12, 2005 | 01:07 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
rebuilt from Ecklers: less than $900....
http://www.ecklers.com/product.asp?p...BSCS4A422WBWA9
or Summit, $599:
http://store.summitracing.com/defaul...=egnsearch.asp
Old Aug 12, 2005 | 02:14 PM
Chopper Larry's Avatar
Chopper Larry
I'd seriously consider the 3.08; the guy who owned my car changed the gears and I'm running 3200 - 3500 at 65-70 mph (est since my speedo does not work...I know I'm running around that becuase the limit here is 65 and a I get passed a lot).
Old Aug 12, 2005 | 02:30 PM
72Tornado's Avatar
72Tornado
I know what kinds of RPMs I'd get on the highway, I was checking it out with a rear-end ratio/engine rpm/tire size/mph calculator. Basically, once I go to college at the end of this month, I have no choice but to leave my car at home (only 30 minutes by bus, but still...). I'm hardly ever going to get to drive it during the school year, and when I do it'll pretty much just be for fun. I'm not going to be doing much highway driving at all, so I'd be fine with the 3000+ rpm highway driving. To me, it's worth the sacrifice...and I might as well go to 3.70's in my situation.
Old Aug 12, 2005 | 02:31 PM
knoxboys's Avatar
knoxboys
I just purchased the complete set up of 3:70's from corvette central. I'm replacing the 3:08's in my big block. I purchased them from corvette central for $1,192 including shipping. I will get a $400 core charge back when I send the old one's back. I should have them in the car in a week or so and will let you know how it goes.
Just an fyi they were shipped direct from a company called Ikerd.
I have the phone number if your interested but they may not sell direct.
I know I have to change the gear in the trans but i'm not sure what color or tooth count I need but I'll start my own thread.
Old Aug 12, 2005 | 02:36 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The 3.08 is probably your best choice. I have 3.55 and at 65mph it's running at >3000rpm...
MidAmerica sells a rebuilt 3.08 unit for 1099 INCLUDING a $300 core charge......
http://www.madvet.com/shop?frame=4.1443
Old Aug 12, 2005 | 04:37 PM
ESU's Avatar
ESU
I've been contemplating either rear end gears or a 4 sp auto tranny swap. I thought the tranny was the more expensive way to go but after reviewing gear prices plus labor it's just as expensive as the trans. I believe my 79 with auto is running 3.73 revving about 3200 at 65 mph, I was thinking about 3.08. Any idea what kind of drop in rpm's I could expect?
ESU
Old Aug 12, 2005 | 05:42 PM
GTR1999's Avatar
GTR1999
Depending on your tire size about 500 rpm. My 308's run about 2700-2800 rpm on the highway.
Remember guys you get what you pay for. Ask the questions on how things are put together just as you would if you built an engine.
Gary
Old Aug 12, 2005 | 05:44 PM
Fevre's Avatar
Fevre
ESU
3.73-3.08=.65
.65/3.73=.17
.17*3200=544
A typical 4 speed auto will drop it by almost twice as much, for a 7000r4 it is a .36 drop (.64 overdrive) plus throw in another 200 rpm drop if you have a locking torq convertor.
Old Aug 12, 2005 | 06:13 PM
ESU's Avatar
ESU
gtr1999 and fevre, thx for the info. Lot of money for just a 500 rpm drop. Droppin the 1000 rpm with a new tranny seems more like it coupled with the lower first gear. I've got a 1990 blazer thats on its last lega body wise but runs great, wonder what tranny is in it? Could be a swap lol.
ESU
Old Aug 12, 2005 | 06:55 PM
Techno's Avatar
Techno
Why not 4.11s?
You could kind of guestimate what you want by taking an arbitrary torque value. A guess of what you already have and doing the math of the rear end ratio on it.
150 ft. lbs with your 3.08s= 462 ft lbs is where you are now at some rpm that equals 150 ft lbs engine torque. Some assumed driving speed/engine rpm.
150 ft lbs x 4.11s = 616 ft lbs.
616-462 = 152 ft lb increase.
3.08/4.11=75% of your 3.08s milage assumed.
18 mpg=13.5 mpg
Or $20 of gas now costs $26.
Old Aug 12, 2005 | 08:16 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I have 456's in my 79 and using a 2400 stall and shift kit. My hwy fuel mileage sucks, but who cares I have fun driving it. If fuel cost were an issue, I'd drive a import (Not ) With the 456's it's an animal from a standing start.
Old Aug 12, 2005 | 08:24 PM
norvalwilhelm's Avatar
norvalwilhelm
What are gears really going to get you?? In the quarter you would be lucky to cut 2 or 3 tenths off your quarter mile ET. Somewhere I have a good test of different gears and it wasn't as much as you think.
With the price of gas I would stick with the 308's. Why drive a high revving gas hog on the highway just to pick up a few tenths if you raced.
Save your money and enjoy the car.
Old Aug 12, 2005 | 08:59 PM
rihwoods's Avatar
rihwoods
Rear gear choice comes down to how you want to drive the Vette...
To Rear gears - recommendations/cost
Old Aug 12, 2005 | 10:11 PM
84rzv500r's Avatar
84rzv500r
just went through the thinking pain myself now to the Wrenches !!!!
Old Aug 12, 2005 | 10:22 PM
Techno's Avatar
Techno
If gas milage was an issue no one would be driving any of these ancient gas guzzlers. These are "impractical 2 seaters" and meant to be fun toys. Not 4 cylinder fuel sippers.
If you want to know what the difference is figure out what it would take to get 150 ft lbs out of your engine. How much would it cost yada yada yada.
That same 150 can be much much larger. Think of it in terms of an engine rebuild.
Old Aug 13, 2005 | 07:30 AM
norvalwilhelm
Gas mileage is an issue. If you get poor mileage you might think twice about travelling any distance with your car. Also if the car is not a good open road traveler agian you think about taking it.
High horsepower doesn't necessarily mean gas guzzling. I put out more horse then 99% of the cars on this forum and still pull down a solid 15 mpg and I don't drive the speed limit.
My friend is running 355 gears with a 350 and he has to buzz above 4 grand all the time just to run with us and we are in the low 2000 range. Who is getting the more comfortable ride, a cooler running motor and better gas mileage.
Gas mileage does count regardless of your income
