TH400 cooling lines: which one.........
Old Aug 12, 2005 | 08:07 PM
73 Vet's Avatar
73 Vet
Default TH400 cooling lines: which one.........
goes out to the radiator, and which one is return (upper or lower on the tranny)? Also, what is the correct direction of flow into/out of the radiator?
Thanks...
Old Aug 12, 2005 | 08:31 PM
fl_rider's Avatar
fl_rider
Default I just looked in...
How to work with and modify the Turbo Hydra-Matic 400 Transmission by Ron Sessions
Bottom fitting on the TH400 - Oil flows OUT to BOTTOM fitting on Radiator
Top fitting on the TH400 - Oil flows back IN from TOP fitting on Radiator
Chris B
I just looked in my TH350 book and it is the same on the TH350
Old Aug 12, 2005 | 08:37 PM
73 Vet's Avatar
73 Vet
Thank you!
To TH400 cooling lines: which one.........
