Thanks, Van Steel
Old Aug 13, 2005 | 09:08 PM
C3 Stroker's Avatar
C3 Stroker
Default Thanks, Van Steel
This is an open "thanks" to Van Steel for the composite rear monospring, the aluminum driveshaft, and the carbon fiber half-shafts for my '69 coupe.....everything installed "by the book" and fit perfectly. Great ride with the new spring, I could have gotten an even stiffer one for my small block and would be comfortable (bought a 380 lb. spring), as it absorbs the road much than the stock one did...oh, yes, it is 380 lbs.- they will custom make your spring whatever wgt. you want if the listed ones are not quite optimum for your needs.......I also didn't know they made carbon fiber half-shafts for C3's until I talked to them (their price was less than competitors ALUMINUM halfs.)....I highly recommend Van Steel for anyone upgrading their suspension.
