Yep, looks like a toasted u-joint....change all 4 on the half-shafts if they are the same age...while the shaft is out, spin the wheel to see how the wheel bearings feel...
ok ..... pulled half-shafts and found one horrible u-joint ..... decided that Big G's idea of replacing all four was a good one ....
have new joints .... replaced one, no prob ..... next one (the one that was bad) came out ok and all seemed normal until reassembly ..... this is on the ujoint flange to the wheel ... when back in place, the clips will not go all the way into retaining slot (one will, the other won't) and when both clips are mostly in, the u-joint is too tight and will not swivel freely ..... I used a vise and a socket to tap out old joints and the vise to press back in. Did i screw the pooch here, or could that have been the initial cause of the failure of the u-joint? I am taking the shafts and other joints to a local driveshaft shop tomorrow (they have helped me in the past), so do I need another flange or a better mechanic?
my thought was this could be a one day job, but of course not to be ... while I was there I replaced the rear shocks ..... (that really needed to be done as I fully compressed the old shocks about 2 hours ago and they have yet to expand ) prolly do the front next weekend
I understand its easy to compress the spindle flange. The one away from the differential. I cut mine in half with a grinder but your supposed to use a "special" tool to buttress this one when taking it apart. I guess it compresses the ears.
Whether its your problem??
You should also check the spindle runout now that the half shafts are out. Just need a dial indicator. If you don't have a harbour freight locally there are other mail order cheap sources.
I have my doubts on the greased U-joints. I wonder if grease comes from all 4 points of the U-joint when greased. If it doesn't then they aren't being lubed.
Anyone with them know?
Techno, I grease them till grease comes out all 4 caps.
Wife'sVette, You may have a needle sideways in one of the bearing cups...Let the driveshaft shop handle the joints, they will be able to straighten the flange if necessary..G/L
Put the dial indicator where the half shaft went, on the spindle.
Then pull it in and out.
.001-.008" I believe although the closer to zero is best.
A few have websites where they've done this so hopefully they'll post a picture. Worth a thousand
big_G. thanks been wondering about that. I didn't get them mostly because they don't fit my lifestyle. I probably wouldn't grease them routinely enough.
