Headers have slight red glow
Old Aug 15, 2005 | 12:49 PM
jimmygmartin's Avatar
jimmygmartin
Default Headers have slight red glow
My new 383 has a slight red glow to the headers on start up. My ignition is set at about 12deg initial & 36deg total advance. I have a mech roller w around .600 lift & 238 duation @ .050, Holly 750 Hp w/mech secondarys, Hooker ceramic coated super comp headers,AFR 195 heads, 9.4 comp ratio. I checked the plugs and they look fine. The carb is brand new and Holly says not to mess with it to much initially as they are very close out of the box (plugs are good). Operating temp is around 200deg on the road. I read that low compression and a hot cam likes more advance, could this be my prob?? 36deg total seems to be what most are running.
Old Aug 15, 2005 | 01:43 PM
Edzred72's Avatar
Edzred72
Originally Posted by jimmygmartin
The carb is brand new and Holly says not to mess with it to much initially as they are very close out of the box (plugs are good). .
Don't believe this at ALL!! Did they set it up for your particular application, or is it just an off the shelf out of the box carb?
Your probably running very lean....
Eddie
Old Aug 15, 2005 | 01:56 PM
NeverFinished's Avatar
NeverFinished
I agree. Sounds lean to me.
Old Aug 15, 2005 | 04:10 PM
Empatho's Avatar
Empatho
Old Aug 15, 2005 | 04:22 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I put a new 770 Holley Street Avenger on my 406, and while on the dyno I found out it was very lean, ended up going up 6 jet sizes front and back to get it where it should be. get to a dyno to check your air fuel ratio asap
Old Aug 15, 2005 | 04:32 PM
jimmygmartin
O.K. you all think it's lean, then why are my spark plugs alright ?? Slightly brown, not white.
Old Aug 15, 2005 | 04:35 PM
7t2vette's Avatar
7t2vette
I would put it on the dyno just to find out, I thought my carb was jetted fine too until the dyno day. If you think about it, how can any carb come out of the box ready to bolt onto any engine? Too many variables for that to happen. A dyno pull will give you an idea where the jetting is
Old Aug 15, 2005 | 04:42 PM
big_G's Avatar
big_G
Too lean at start-up? How is the idle mixture?..
Old Aug 15, 2005 | 04:47 PM
Boofers's Avatar
Boofers
Holleys a usually a bit rich out of the box...
Check this thread out:
http://forums.corvetteforum.com/show....php?t=1159550
Oh wait thats your thread...
Old Aug 15, 2005 | 06:35 PM
7t2vette's Avatar
7t2vette
rich or lean, either way a dyno run with an wideband sensor will let you know
you say your plugs are tan, and not white or black, this is the easiest way to find out!
Old Aug 15, 2005 | 06:39 PM
Duke94's Avatar
Duke94
I had the same problem with my 350 after rebuild. Turns out the timing was not advanced enough for the cam etc I used. Finially, I set the timing as Lars outlined. Short version... set the timing to 36 degrees at full mechanical advance (3500 RPM's or so) and never mind what the idle timing is. I started out at 12 also, now up to about 18. My headers were VERY red at first startup. Search the forum for Lar's "how to set timing" article.
Old Aug 16, 2005 | 10:55 AM
jimmygmartin
The dyno is a great idea and one that I had thought about even before I fired the engine. Does anyone know of a dyno tuner in the central New Jersey area???
Old Aug 16, 2005 | 03:43 PM
mrvette's Avatar
mrvette
NOthing rong with dyno tuning, BUT.....
if it's dark out and you see red glowing...i'ts normal...
if you see yellow...i'ts NOT NORMAL...orange is getting close to problems....
IF you see that glow in daylight....you got issues...but at that point the plugs should show it also...
GENE
Old Aug 16, 2005 | 11:05 PM
seacliffe301's Avatar
seacliffe301
My experience with red glowing headers was corrected
with an 850cfm carb. No apparent timing issues.
Good luck.
Old Aug 16, 2005 | 11:12 PM
big_G's Avatar
big_G
GENE
Think about it...the only thing between red hot exhaust and the outside world is 18 gauge steel....dull red=O.K., if viewed at night
Old Aug 17, 2005 | 11:19 AM
CGGorman's Avatar
CGGorman
Optimum exhaust gas temperatures appear to be about 1,200 degrees.
Optimum A/F ratio appears to be 12.5:1.
Optimum TOTAL timing appears to be 36 degrees.
Temperature of bare steel, judged by color:
Red heat, visible in the dark.......752
Red heat, visible in the twilight...885
Red heat, visible in the daylight..975
Red heat, visible in the sunlight 1077
Blood Red .............................1200
Low Cherry Red .....................1375
Medium Cherry Red .................1425
Full Cherry Red ......................1500
Scale forms and adheres at about 1850
Old Aug 17, 2005 | 12:48 PM
jimmygmartin
In my case the center two pipes (small block) have a slight visable glow in the day light but in the garage not direct sunlight. This also occurs when My electric fan hasn't come on yet (not that it will blow enough air to cool down already hot headers) I've always run an engine driven fan. So based on what you've written it appears to be O.K.
Old Aug 17, 2005 | 02:15 PM
PatsLs1vette's Avatar
PatsLs1vette
try east coast supercharging near new egypt
To Headers have slight red glow
