Yet another starter question..
and it's a 4-spd, not an auto. I found a local mechanic willing to work on it and drop it off at DAS. About 3 weeks ago they finially finished fixing the e-brake (and charged me $200), and dropped it off at the shippers. Yesterday I start trying to track it down wondering why I hadn't heard from them and found out that 1) they didn't have my cell phone number, only my wife's, and she cancelled it a month ago, 2) the car is actually in Utah waiting for me, and 3) it won't start with the starter motor, only push starting it.I called the mechanic and he said it was fine when I dropped it off with him, fine when he dropped it off at DAS, and fine when he had to drive it around. According to DAS, they tried jump starting it and have push started it a number of times, but it NEVER started with just the key. Trying to add it all up I vaguely remember there is some kind of relay related to the ignition somewhere around the e-brake handle, and since that was adjusted, I figured I go pick up the Corvette and probably find a loose wire in there. Nope, I couldn't find anything loose and I had to be push started.
When I got home I tried to start it and it starts right up. The starter itself is new, I replaced it last summer when I had this problem. Obviously replacing the starter wasn't the fix, but now I'm afraid to drive it anywhere. I wish it wouldn't start so I could find the problem.
Any ideas???
I can't seem to find my haynes manual.. How do I get to this 8 wire connector? I'm guessing it's way up in the dash and is a royal pain to get to.
If this isn't the problem, what would be the next place to look?
I've heard of jumping the starter, what's the best way to do this without causing problems or shorting something out? The wife made me park in some fresh layed gravel 'cause she didn't want me to drip oil on her driveway which I promptly sunk in. I can't push it out otherwise I'd push start the car and get it to my place.
What about the clutch safety switch, or whatever it is called, you know , the one around the top of the clutch pedal that only lets you start when the clutch is engaged??
I should mention that the car was push started, driven to my wifes house and parked, and it immediately started back up. After sitting not being driven in a week it will not start. Battery seems ok, but I tried jumping it off my jeep anyway. Last night I had the wife check to see if the headlights dimmed at all when turning the key and they did not. I'm pretty sure current just isn't getting to the starter.
To be certain try running the wire to the other solenoid wire and repeat to make sure you had the right wire.
This will insure that you are not chasing the wrong problem.
You're correct in that I should probably start with the starter, but it's a pain to get to and since I'm at my wifes house during the day (I work remote and I'm waiting for Internet access at my house) I can take 5 minutes here, 10 minutes there, and check out things like this.
I'll try jumping the clutch switch wires probably tomorrow.
Leaving it jumpered I tried to crawl under the car to see if the starter looked well connected. In doing so I remembered I gave away my jack and jack stands when I moved from FL to UT, and as low as the car is all I can do is feel around. All the wires feel secure.
Thinking I might have a loose cable and being in a not so pleasant mood I tore my console apart looking for the relay. I found it I believe (roughly under the ash tray, a few purple wires and a thin black wire), but it was plugged in ok and all the wiggling in the world will not get it to start.
Now I'm really frustrated. The car hasn't started in months, the cables are pulled off the clutch safety relay never to return, my console is tore apart, some of the brittle 25 year old plastic parts are now broke, the driveway is too steep for me to push the car into the garage, and since I'm going through a divorce I have no money to have it fixed.
