TH 400 Wire
Old Aug 18, 2005 | 01:25 PM
71stockray's Avatar
71stockray
Default TH 400 Wire
Dropped the pan on the 71`s TH 400 this week. I noitced a wire running through the valve body with a wire terimnal on the outside of the transmission case. Is this part of the long ago removed equipment?
Old Aug 18, 2005 | 01:29 PM
73 Vet's Avatar
73 Vet
It's for the kick-down. The switch is located on the accereator pedal mechenism.
Old Aug 18, 2005 | 01:43 PM
71stockray's Avatar
71stockray
Transmission kicks down fine. No switch on gas pedal either.
Old Aug 18, 2005 | 03:06 PM
markdtn's Avatar
markdtn
If you have TH400 then you have a single male electrical terminal on the drivers side outside the case above the pan level. It has an wire going to it. That wire leads to a switch-usually on the pedal assembly-aftermarket at the carb. FRom the switch there is a wire to ignition switched power. That is the kickdown on a TH400. When you achieve full or almost full throttle, it kicks down a gear.
Old Aug 18, 2005 | 03:51 PM
NHvette's Avatar
NHvette
Should be an orange wire.
To TH 400 Wire
