I have a line on a very good price for a fluid dampened harmonic balancer. I know that it probably isn't worth any extra money from previous posts, but I do think that it's
My concern is that my current damper is 6 and 3/4 inch diameter. There doesn't appear to be such a thing as a 6 and 3/4 inch fluid damper. Instead, this size seems to be 6 and 1/4 inch. One obvious concern that I have is will the 1/4 inch gap between the timing mark and indicater matter? Also, is there such a thing as a 6 and 3/4 fluid damper in which case, am I being offered a good deal on something that doesn't fit?
Size itself doesn't matter for balancers, but weight does..
The engine will rev up quicker if a lighter balancer is used which will result in better track times.. 1 - 2 lbs won't make a huge difference, but if you would go from a 13 lbs 8" balancer to a 6 lbs aluminum balancer, you will definetely pick up ET on the 1/4 mile...
As always, thanks for the input guys. I went ahead and bought it. When I install it, I'll let everyone know how it worked out. Might not be a fair comparison though. My old balancer was so far out of whack that I had to tune by ear. Car runs great but seems to have an issue with detonation
???? Wouldn't changing to a lighter weight balancer require rebalancing the rotating assembly?....I'm referring to an externally balanced engine...
I don't think so...
If you have a 350, just get a 350 external balanced balancer or if you have a 400 or 383, get a 400 external balanced balancer... It doesn't matter how heavy they are. The only thing that matters is that they were balanced for the appropriate crank used..
Here's an example for a lightweight, external balanced balancer:
Thanks for the link...I have a 383 and am considering a lighter balancer.
I use a Romac balancer on my 406.. Unfortunately, the aluminum balancer isn't available for my crank because Scat and Eagle forged cranks are undersized and require a undersize balancer.. The undersize balancer is only available in steel
A quick update on the instalation of the silicone dampened balancer.
I put it in this morning (first day back from holidays). As described above, a very easy instalation. It's amazing how easy it is to do jobs like this if you have the right tools. With the proper intalation tool, the only thing that could have made it a little easier would have been a 1 1/8 inch ratcheting wrench. Because of the location and the length of the wrench that I have in this size, I had to install in very short swings and it took about ten minutes.
Since I haven't rebuilt my power steering pump yet, I just went ahead and started it with no belts or pulleys on. It ran very smoothly and seems to rev a little better, though this could be my imagination. It's also the first time that I've heard this engine run without the belt squeek and I'm looking forward to driving it this way.
I did not notice any difference at all with the reduced diameter. If I didn't know that there was a difference in diameter, it wouldn't even have entered my mind.
The one thing that I don't like is that I bought a black balancer and even though the markings are embossed, they are not painted. Does anyone have a trick other than rubbing chalk in the mark to make it easier to see with the timing light?
