Radio Wires?
Old Aug 18, 2005 | 06:55 PM
csams's Avatar
csams
Default Radio Wires?
72 Corvette....original radio is long gone.
Which wires do I use to hook up a new radio?
I am assuming that:
Yellow = ignition switch on/off
Gray = constant power
Black = ground
The gray and black wires run together in a plug.
Pls comment.
Old Aug 18, 2005 | 07:58 PM
Gordonm's Avatar
Gordonm
The gray wire is for the dash lights and the radio lights. Power is on only when the lights are on. Yellow is power, black is ground.
Old Aug 19, 2005 | 05:11 AM
RHD '68 L89's Avatar
RHD '68 L89
You will have to source a continuous power for the radio memory, use the orange feeding the clock and cigarette lighter. Yellow is switched power so the radio turns off with the ignition.
To Radio Wires?
